Recommendations for a GPU?
Looking for a GPU preferably a GTX 770. Im looking the best value GPU that will give me the best preformance of around a 770. I saw the videos on the EVGA superclocked card and was wondering if it was worth the value, im not a hardcore gamer but i play games like BF4 and cyrsis with relatively good graphics. Leave recommendations!
thanks,
-Krak_Ur_Nutz
Personally, I'd say spend a bit more and get a R9 290 (Non-X). It's only $50 more than the EVGA Superclocked 770. Maybe wait for an aftermarket cooler if you're worried about temps or noise, but it's barely slower than the 290X and on par with the 780, but $100 cheaper than the 780. Looks like it's going to be the best bang for the buck card of this generation.
See what $50 more gets you...
http://www.techpowerup.com/reviews/AMD/R9_290/7.html
Or get two of the 280x/7970 cards for tons more performance!! I have a 7970 and 7950 in CF in BF4, consistently stay around 70 (sometimes I dip to mid 50s) at 1080p with ultra everything, 2x msaa and 145% scaling for SuperSampling. You'll get more than that with the 280x and/or 7970 CF. The 780 and 290x don't really compare to that. mind you, the 280x is at $300 each and you get free games, too!
EDIT: I understand that this is a more expensive option than the 770 or 290, but price:performance is way up in comparison.
I would not recommend dual GPUs, too much hassle and lots of noise, heat and power consumption.
Gtx 770 is a solid value. The evga ACX looks so good but it is certainly mediocre in terms of noise and cooling compared to the MSI gaming and windforce 3. Look up some reviews of each and decide.
I recommend AGAINST 290 reference but if non reference drops I would recommend that over a770/280x because lots more performance for only a modest mark up in price depending where you live(only 50 euro extra in europe).
