Recommendation of VM's for a first time user
Hi everyone, it’s my first time posting.
i have been searching online witch vm’s is the best for my use case and wanted to get some of your opinions /critics about thems to have a bigger picture.
At the moment i stear towards VMware, Virtualbox, Microsoft hyper-V and proxmox (maybe gonna try red hat vm for the knowledg of it later).
I want to have a reliable and safe one that won’t interfere with my main system / os (i guess they are all ok on that side)
I wan to try custom os (windows modded and linux distros) and run software on thems.
Also to my knoledge they shoud all create a cluster so nothing get out of the vm’s for safety resons (ikik it’s one of the point of vm afterall, just still asking incase i am missing something)
Apart from that i did use vm ware twice but it was years ago.
Thank’s in advance for your help.
There is 2 types of VMs here. Bare metal hypervisors, where the hardware is dedicated to the task of running VMs. VMware ESXi, Proxmox, and some installs of Hyper-V will do this.
Then we get hypervisor as a desktop app, like VMware Workstation/Fusion Virtualbox, and Windows Server with the hypervisor/ hyper-V role installed.
Everyone is flocking away from VMware ESXi after Broadcom bought them out. I am not sure they even offer a free home version of ESXi or anything anymore.
I like Proxmox for a bare metal hypervisor. And Virtualbox for running a desktop VM for testing stuff.
Welcome! pull up a chair and stay a while!
depending on your goals all of those could be good options.
if you simply want to have something on your computer that can host vm’s hyper-v is a great option to start with and can be simply “turned on” if you have a pro version of windows. otherwise virtualbox is also a great option, but may not give you the best performance.
If you are able to setup another pc specifically for virtual machines I would recommend proxmox. It is relatively easy to setup and use, gives you (easier) clustering and HA options, and it is the “in” thing with homelabers so you should be able to find the answers to most questions you could have on these forums. I suggest looking at Proxmox Backup server as well, it greatly reduces the storage cost of backups and expands the capabilities. regarding clustering please look up the risks and downsides first because it may not be worth it always.
if you are more focused on learning for enterprise the answer could be anything from xcp-ng, vmware even hyperv… the list goes on.
whatever you end up going with, feel free to play around and experiment. you don’t have to feel stuck with one option. you could even experiment with a hypervisor within a hypervisor! (just be warned about the performance weirdness and bugs that this causes)
as for me, I am currently using a mix of proxmox, hyper-v, and xcp-ng.
Thank’s for your infos. I won’t go with VMware then. Now i decided that i will try virtualbox and Microsoft hyper-v manager and see witch one i like the most. Also i plan to build a small custom nas/server with proxomx probably next mounth :grinning_face: .
Thank’s for the comment.
I will certainly use proxomx for my future project with dedicated hardware now. I didn’t tought of all the benefit with all the backgroud the community did build over the years. Proxmox definetly as a bigger enthusiast / homelabing community space from what i have seen compared to some others vm’s.
Great point from you.
