Device: /dev/ada4, Read SMART Error Log Failed
Device: /dev/ada5, Read SMART Error Log Failed
I built a NAS server not so long ago, and got 6 WD red drives in there.
Recently I've been getting these emails, and made nothing of it, however now it happens almost monthly.
It started out being ada2, then ada4 now its ada4 and ada5.
Can anybody give me a straight answer to whats happening here? Should I be worried?
What OS is the the NAS running?
First, i would recommend reading this and check the drives health and test the drives with smartctl. On the second link the examples on how to use it will be the FreeBSD ones since under the hood FreeNAS is FreeBSD bundled with a few other things. You are going to need to SSH into the the FreeNAS box and su into a root shell to run the commands.
smartctl is now running, will keep you posted.
Results are in, however I am not sure how to read them.
/dev/ada4
[root@freenas] ~# smartctl -a /dev/ada4
smartctl 6.3 2014-07-26 r3976 [FreeBSD 9.3-RELEASE-p16 amd64] (local build)
Copyright (C) 2002-14, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family: Western Digital Red
Device Model: WDC WD10EFRX-68FYTN0
Serial Number: WD-WCC4J3TJVDNC
LU WWN Device Id: 5 0014ee 261035d4f
Firmware Version: 82.00A82
User Capacity: 1,000,204,886,016 bytes [1.00 TB]
Sector Sizes: 512 bytes logical, 4096 bytes physical
Rotation Rate: 5400 rpm
Device is: In smartctl database [for details use: -P show]
ATA Version is: ACS-2 (minor revision not indicated)
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Tue Jul 14 13:57:15 2015 CEST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x00) Offline data collection activity
was never started.
Auto Offline Data Collection: Disabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: (13800) seconds.
capabilities: (0x7b) SMART execute Offline immediate.
Auto Offline data collection on/off supp ort.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 2) minutes.
Extended self-test routine
recommended polling time: ( 157) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x303d) SCT Status supported.
SCT Error Recovery Control supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_ FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0027 134 134 021 Pre-fail Always - 4291
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 44
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0
9 Power_On_Hours 0x0032 098 098 000 Old_age Always - 1606
10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 44
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 19
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 34
194 Temperature_Celsius 0x0022 107 101 000 Old_age Always - 36
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 0
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
Num Test_Description Status Remaining LifeTime(hours) LBA _of_first_error
# 1 Extended offline Completed without error 00% 1598 -
# 2 Extended offline Aborted by host 90% 1596 -
# 3 Extended offline Aborted by host 90% 1596 -
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay
/dev/ada5
[root@freenas] ~# smartctl -a /dev/ada5
Serial Number: WD-WCC4J3TJV7TK
LU WWN Device Id: 5 0014ee 20bae47ca
Local Time is: Tue Jul 14 13:59:41 2015 CEST
was never started.
been run.
data collection: (13680) seconds.
Auto Offline data collection on/off support.
command.
power-saving mode.
recommended polling time: ( 156) minutes.
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
3 Spin_Up_Time 0x0027 132 132 021 Pre-fail Always - 4375
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 35
No Errors Logged
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
If Selective self-test is pending on power-up, resume after 0 minute delay.
Good news is both drives appears to be fine. So times error like this have been cause by bad cable to bad power supplies. 99% of the major drive problem are account for in the long test.
