Razer Project Christie Fully Modular Gaming PC Concept
Have you seen it ? If not watch this
http://www.youtube.com/watch?v=1FW78IAfybI
I want you to post you opinions will this become like standard in PC ( to have something like that) or it will be next expensive thing that almost nobody have ?
i like the idea of it and it seems very out there. and for the people that don't build PC's and repair or fix them its a good idea. the only thing that i see that it might not have a retail release in the near future it the panels that are modular have to be build the pcb has to be custom made. so if razer can keep there cost down and as of razer products they are never cheap for whats really in them like the laptop they made
Its going to cost way to much and since it's proprietary, that means Razer can mark it up all they want
this should be marketed as modular oil bath cooling for enthusiasts, instead it's being marketed as " 'expansion cards' are scary and complicated but 'modules' are simple and easy" EVEN THOUGH THEY'RE THE EXACT SAME FUCKING THING, this is just fucking insulting to everyone's intelligence, then again no-one ever got rich by expecting humans to have common sense
Oh and did you see the ram and CPU come together in an unexpandable sealed unit meaning if you want more ram you have to buy a new CPU as well
unavoidable, because of the nature of ram it needs to be right by the cpu, and it has to be sealed otherwise the oil will make a horrible mess
though I suppose the ram slots could be placed on the outside, but that ruins the (horrible) aesthetic, and/or involves a bit of extra engineering
Actually there is a way around it. You could create a daughter board that sits right next to the CPU and is not submerged in the oil bath therefore allowing the ram to be changed. Or seal the backside of the board from the mineral oil and put the ram on the underside of the board, like some laptops do. The point is there is a way around it and a lot of the solutions are as simple as put the ram in a sealed compartment that allows the ram to be changed.
But if you figure all that so you can change parts and other things it will be damn too expensive ... and If they don't make it from some really solid material all those components could just fall appart and don't forget that if some pipe fails it might spill all this oil around your house and they sould add like some tools to open up those ''cards'' and if you have like kid walking in your room first thing that he will be touching are those ''cards'' so yeah ...
Allowing changeable ram would not compromise the system, everything would still be sealed but there could be 1 isolated panel that you would remove in order to change the ram. And I never said anything about making out of cheaper material, aluminum is easy to machine and making a hole to change the ram would not compromise anything at all
I am just sayin that it needs to be built like rock because of those connections where pipes are connecting
It would still be solid, the only problem I have is that it is 100% proprietary meaning they will get free reign over the price and they WILL overprice it
Yeah it will be overpriced that's for sure, simply because they are the only one that have done it
That's why I like the ATX standard, it keeps price fixing down, so I will still be putting computers together the old fashioned way. But I also like putting things together and this thing looks like no fun
Yeah and when you are playing game and you are pround of yourself because this machine that you have been buildit is so awesome and you feel like it's your ''baby''
what would you estimate the price to be?
