Or should I get a macboook instead? I just want to play minecraft at around 30fps.
http://pcpartpicker.com/p/EwYq
Nah that won't run it. Only a supercomputer from Germany will run it at 30fps unfortunately. Going to have to spend more than 28k.
I heard that SSDs increase the speed of your computer. What if I add like 3 more 10k SSDs?
If you want to play minecraft at 30fps you could literally spend no more than $400 on an APU based system.
http://www.youtube.com/watch?v=5NoONgFEUo8
Note: Would recommend stepping up to the A10-5800 (or whatever it is)
You should not use that setup as it is an old socket with an outdate processor.
Also you are using 2 different memory kits in a triple channel board/processor.
Quadro GPU... really?
Jesus 65g of thermal paste? are you planning on smearing it on your face or something? 4g would be plenty.
- zanginator
It's kind of funny that you threw a quadro in a trolo build, because they suck for games.
Lol, what the fuck is this trolling bullshit?
If you have that kind of money then do this: http://pcpartpicker.com/p/EA2O
Add a Razer Ouroboros gaming mouse, a receiver, a couple of Klipsch RF-82 tower speakers, a Klipsch SW-112 subwoofer, and a full custom water loop including an XSPC Raystorm CPU block, full cover blocks for the motherboard and video cards, two Swiftech MCP655 pumps with a dual pump top, an Alphacool NexXxos UT80 360mm radiator, an Alphacool NexXxos UT80 240mm radiator (and some velcro to mount the SSDs so you have room for the second radiator), a FrozenQ tube reservoir, Corsair SP120 Performance fans, Ice Dragon Coolant, some tubing, and some custom lighting.
Throw the SSDs and HDDs in their respective RAID 10 configurations and you're good to go for the next 5 years probably.
