Fed up with door dingers damaging your car? How about a dashcam that captures video of them doing it?
Tesla has a feature called “sentry mode” that does this, but it’s got issues and you need to buy a Tesla. But maybe something similar/better can be made with a Raspberry Pi.
Connect 4 USB cameras, front, rear and both sides of the car. Write some software to capture video to SD card.
Main problem is power consumption. In sentry mode you need to capture images at say 1 fps, and switch to proper recording mode when some activity takes place. Maybe there is a better way, like using an accelerator to detect stuff hitting the car, but would it be good enough to notice door dings and scrapes from keys etc?
Can’t just throw bigger and bigger batteries at the problem, because they have to be recharged. If your commute is only 15 minutes then you need to charge enough in 15 minutes to run for 8+ hours.
Mastic_Warrior, I think you are under-estimating the power requirements. I did a quick calculation and say you are pulling 5W average ([email protected]), if you bought 3 massive 3500F supercaps you could run for about an hour. They cost €75 each, by the way.
cdoublejj, your idea seems more practical, although with a hatchback and tinted windows it will need a creative way to install it.
Need to make use of the traction battery really, but there is no easy way to do that.
Maybe the Pi is just too high power. What you really need is an ultra low power system just monitoring an accelerometer for dings, which then wakes up the recording. Problem again is that the Pi won’t wake up fast enough to capture anything useful.
I have two rpis in my car. One for multimedia and dashcam and the other is for rear view and engine reading(not finished yet), so I have experience with HATs and configurations.
If it has to be on 24/7 then connect the pi directly to the car battery. (this shouldn’t be that hard)
For powering, use one of these (I am using the first one and it’s good, no undervoltage problems):
OR
You could even go overboard and buy besides that a UPS HAT and get a 4400mAh battery for extreme cases when the car battery would die. Also alot of UPS HATs have the feature to shutdown the rpi if main power goes out. On top of that it’s gonna ensure no footage will be corrupted because of power outage.
The rpi Zero is the best for single camera but you could buy a rpi 3 and use the USB for additional USB cameras to cover all the angles. Maybe a rpi zero with a USB HUB could also work? I don’t know.
Thanks alphazero1990. I’m wondering how fast I can charge a lipo battery pack. Problem is when you search for ones with fast charge capability they all mean on the output, not to charge the pack. Typically 1C is the maximum rate but of course it’s 1C per cell, so with a massive 20Ah battery and sufficient cooling you could probably charge enough to get decent run-time.
What did you use for dashcam software? I should look at what is out there. I was thinking of just writing something myself.
Do you have a have some system in place to detect when the ignition is on?
Doing a little research it seems like you can actually get the power consumption of a 3B down to a little under 400mA idle. You can also put the USB into suspend, maybe even cut power with a FET but suspend is supposed to be sub 10mA consumption, so if only grabbing one frame per second maybe the cameras can sleep most of the time.
There is a thing for ignition detection actually, it’s a power supply/converter like the ones I have posted with that feature.
But for what I suggested Car Battery > Converter > UPS > RPI you wouldn’t need an ignition detection if it would run 24/7. Maybe add a button where you can shutdown and startup the pi when you come home.
Ofcourse there are many options to solve this problem : D I am just brain storming here xD.
home made car battery sized 18650 battery pack out of used 18650s and put it in the trunk or just buy an AGM battery and stick that in trunk, charge off the alternator but, idk if the alternator would need upgraded.
On average a Raspberry Pi 3 is fairly low power even with two USB devices plugged in, you’d have to tweak the sensitivity–also if you have an old phone, sometimes you can unplug the flex-cable and reuse the accelerometer & camera modules. If you want to be creative with off-the-shelf battery packs, calculate your power requirements and buy or custom build your own power solution(there are kits out there which can scale to support for charging while driving similar to a phone charger). Depending upon were you live if the weather is “warm to hot” the batteries are less likely to lose charge vs colder environments which a battery can easily go from 99% to 50% in a jiffy.
In my opinion if you downscale to just a Pi Zero the power usage will be much lower and realistic usage shouldn’t need more than two cameras. If you’re paranoid there are 360 degree camera solutions which uses a mirror–I no longer have a link but I once found a YouTuber who modified a Sony blog/action camera 360 attachment on a webcam.
I think it’s going to need to have some smart features to limit power consumption. You can add a bigger battery, but you can’t charge it in the available time when the ignition is on.
I’m thinking it should only run when the car is parked away from home and work, because those locations already have CCTV.
PaintChips, there are commercial dashcams with 4 channels. They are very new so no reviews yet. The side cameras are supposed to clip on the wing mirrors, I guess mostly designed for trucks.
