Raspberry Pi B 4 is out
They’re willing to offer different SKUs based on feature now. They’re doing it for RAM. So I don’t see why they couldn’t make one with two USB-C ports rather than mini-HDMI and a M.2 NVME port rather than SDcard.
Of course there could be manufacturing cost considerations. Perhaps the 1/2/4GB models are all identical, just with higher density RAM in the same physical configuration.
That will depend on the number of PCIe lanes on the SOC.
I would too, but it’ll be prohibitively expensive. You’re likely to see a near doubling of price.
I don’t see why, there’s no licensing cost, it’s just the bill of materials for the part and routing PCIe lanes over. I really don’t have any way to evaluate whether that would cost more or less than a SDcard slot. I would guess more, but certainly not $35 more.
I don’t think they have the lanes for it, otherwise they’d have allocated more lanes for the USB and NIC.
So they’d need a different SOC. Which will be more expensive.
We really have no way to tell how many pcie lanes the onboard controller supports. All we know is there is one. They could have cost constraints there too. RPi is designed around that $35 price, first and foremost.
Finally this could make a decent, low power NAS.
Any word on H.265 deocding? That’s the one thing missing with Kodi on Pi at the moment. Well, that and a decent YouTube client.
I believe they said they have it.
Edit: just confirmed it, yeah, h265 is there.
I am not sure if Pi4 will be a better solution for low power / small 1x HDD NAS compared to Odroid HC2, HC1.
Although it all depends on individual needs. :wink:
Do you mean the Fyde OS project, or is there another?
How would it even work as a NAS? You plug in a bunch of external USB drives? That’s some ghetto scheisse right there.
That is how Apple imagined pros would work. The Trashcan on a 6 high stack of external Thunderbolt HDDs.
Could do an enclosure. If nothing is critical it is a better solution than using the USB port on a router.
Can have a usb raid enclosure… but at that point I would rather just get a dedicated NAS like Synology.
DAS USB raid enclosures are a thing that exist, and I suppose USB3 does have sufficient bandwidth for 4 magnetic drives. It isn’t a completely ridiculous idea but it certainly isn’t something I would do.
Are there any USB<->SATA adapters that support SATA multiplexing? I have an enclosure with a built-in multiplexer.
My Pi 4 has landed :slight_smile:
Once RaspBSD has support for it I’ll play around with that. In the mean time it can keep my MIST company, and will be used for general mucking about.
But can it run WoW?
How does it run as a desktop? Is everything smooth/responsive/snappy?
So far so good, better than I expected and much, much better than a Rasp Pi 2 I’ve played around with in the past. It’s has no trouble with some external EXT4 USB3.0 drives I have - although one encrypted with LUKS wouldn’t unlock, so I need to figure that one out.
I know you are probably joking, but with QEMU + Wine it might be possible. FPS is probably not gonna be that great though haha.
Maybe missing hardware acceleration is the cause ? It probably should fall back to software mode though. Whats the speed like for read/write operations?
