Hello everyone, the other day i was told by someone that you could overclock your ram so i looked online to look for guide on overclocking my ram (Patriot Viper 3 16GB (2 x 8GB) DDR3 1600MHz (PC3-12800) Dual Channel Memory Kit (PV316G160C0K)) but i could not find one so i am hoping that someone on here had a guide for me or the settings they are using.
i dont know a guide for it but i can explain it a bit:
the main things you can overclock on your ram is your cas and frequancy, the normal cas and frequancy is cas 9-10-9-24 i believe and frequancy 1866 mhz so try to rise that bit by bit and raise the voltage the standard on ddr3 is 1.5 v so dont go below that but check your specific ram spec on the site or in the dimms itself because it can vary.
