Ram help
help my z87 motherboard doesn't recognize my ram
Asus suggested to:
disconnect everything; try only one stick; pull bios battery; bios update; and new ram
i have tried all except for bios update and new ram
also my ram is not on the Asus list of supported ram
it is g.skill F3-2400C11D-16GXM ram
   bad sticks or just not the recommended sticks
also how do i do the bios flash
halp :(
Try one stick at a time, and make sure they're FULLY pressed in.
Can't help you much with a BIOS flash, but your motherboard may support the USB-only flash feature that Asus has on some mobos.
i tried that
How far does the boot go to?
Try both sticks one at a time in the slot FARTHEST FROM THE CPU.
everything has power but no display it only gives me error codes on the mobo it's self
finally posted installing mint now
mint is running quite snappy now however i tried adding my other stick of ram and it refused to boot, i removed it and it booted right up
is there any way to make it stop doing this i seriously want to run all 16 gb of my ram
Run Memtest86 with each stick.
You might have a bad RAM stick.
Sounds like a bad stick. If you bought them as a pair then RMA or Return them and get new ones.
ok i will test them
