martona
1
I got a couple of “naked” blower fans; Delta makes these specifically for you to design the housing around it. Talking about this one in particular:
Is it better to close off the side with the mounting bracket completely, or would leaving it (partially) open help?
The Radial fans I have make an effort to feed air into the rotor from both sides.
martona
3
Thanks for the quick reply!
I sort of figured it might help because the impeller blades are more or less symmetrical across the plane, at least on this fan design.
