Radeon Vega 64 Thermal Pads
I have a Radeon Vega 64 Reference card from MSI that I installed a full cover water block a few years ago. However, started to develop around where the fittings screw on. I still have the stock cooler, but the thermal pads were mostly destroyed when removing it. Is there anywhere I can find a list of the sizes, thicknesses and places for each thermal pad?
Recently cleaned my old Vega 56 and i think i used akasa 1mm and/or 1.5mm pads (they sell them in like 20x20cm sheet package).
You can always test-fit them and see if they make contact
Original pads locations (on sapphire nitro+) if that helps you
6? tiny gray squares and 1 larger pad on right:
Correction:
I used ARCTIC thermal pads 10x10cm sheets, cut to the size, obviously
