I need to know if it will be worth the extra $100 for the 7950 or if I should just go with the 7870, I want to knout what the difference will be in maxing out BF3, Metro 2033, Crysis 3, and just overall performance difference. The only other thing I'll be doing is a bit of bitcoin mining
personaly i would lean to the 7950 just a bit better all around. but the 7870 is nothing to scoff at either. so pick the one that hurts your wallet the least and you will be happy.
What I'm looking for are side by side comparisons of performance using the cards, seeing as I'm not getting many replies/info I'll probably buy Radeon HD 7950
Get the 7950 deal on newegg today. It's like 250 dollars for a 7950. Dunno if it's still going though.
That being said, a 7870 XT is an amazing card, and is basically a 7930. Best way to describe it. A 7870 xt has the same processor (tahiti le) as the 7950.
i just set the texture resolution to very high, didnt touch the antialiasing.. system spec set to high.
and it was very well playable ☻
about 30-45 fps, and somethimes 50-60 fps, but mostley around 30-40 fps, somethimes it drops back with very much quick and much movements, to about 28 fps, but its very well playable, on thease settings.ofc not everything maxed out.
for that you realy gonne need a 7970 i guess. but for a stock 7870 ghz not bad at all.
