Hi everyone,
I’m working solo on a a privacy‑sensitive documentation assistant for psychotherapists. It’s a RAG-based system (backend + vector search + web UI) designed to help clinicians transform session information into structured drafts, final documents, and exports, with auditability and source traceability built in.
I’m currently operating with limited/no funding, and that’s exactly why a Radeon AI PRO R9700 would be genuinely impactful: it would remove a major bottleneck that’s standing between “working prototype” and a realistic first MVP rollout.
Why the GPU matters for this MVP (not just “more speed”)
This isn’t a toy chatbot. The MVP needs to be:
Reliable (repeatable outputs, fewer failure modes)
Fast enough for real workflow use (interactive drafting, extraction, template filling)
Privacy‑aware (supporting local or hybrid processing options)
Testable and maintainable (regression checks, quality evaluation)
A stronger workstation‑class AI GPU directly helps with:
1) Local / on‑prem readiness for privacy constraints
In mental health settings, not every workflow can comfortably depend on external services. Having the capability to run more of the pipeline locally (or as a hybrid) is a practical MVP requirement for many early adopters. The R9700 would let me prototype and validate these modes without expensive infrastructure.
2) Faster embedding + indexing iterations (core of RAG quality)
RAG quality lives and dies by ingestion and retrieval. With more GPU headroom, I can:
Embed and re‑embed corpora faster
Iterate on chunking strategies and retrieval evaluation
Reduce “missed context” issues and improve grounding
That’s the difference between “interesting demo” and “clinically usable tool”.
3) Practical evaluation and regression testing as a solo developer
When you’re alone, time is the scarce resource. Better compute makes it feasible to run:
Larger test corpora
More frequent end‑to‑end regression checks
A/B comparisons of retrieval and generation strategies
That directly improves stability and confidence for an MVP rollout.
4) Enabling next-step features without cloud spend
Features like structured extraction of session notes into tagged blocks, updating a longitudinal case file with reviewable diffs, and template‑constrained generation all benefit from more compute. The GPU would let me push these forward without relying on paid infrastructure that I simply can’t justify yet.
Bottom line: With limited funds and a solo dev setup, hardware is often the deciding factor between “I can build it” and “I can ship it”. Winning a Radeon AI PRO R9700 would remove a huge barrier for delivering a first real-world MVP rollout—faster iteration, stronger local/hybrid capabilities, and more reliable quality assurance.
Thanks for reading—happy to share more details about the stack, the RAG pipeline, or the evaluation approach if anyone’s interested.
-Mario
