They're the same card, only difference is in clock speeds and the 280X might use a bit less power due to some optimizations, but performance-wise, they're the same.
280x looks like something that would break in my hand. Asus 7970 actually feels like something that is worth $300. Only time I'd suggest a 280x is if your making a ITX rig.
280x isn't omg I need it now. 7970 still does everything that 280x can do minus 1.2 FPS and 100mhz. Wow such a jump in performance lol. Only thing they did better is making perform as equal, but only making it a 2 slot asus version.
The parts shop here just started stocking the 280x, and it's $399. A 7970 costs $450 - $550 depending which brand/variant you look at, while the GTX 770 is $500 - $600, and from what I have read the 280x competes well with that card.
Yet when I started reading some reviews and articles to decide if I should upgrade from my 7850, they all seem to say the same thing... "Doesn't offer anything new, just get a 7970".
One article even compared MSI's 280x to a 760, and said that nvidias 7xx series wins on price/performance.
Are people just so jaded about not having a brand new architecture straight away that they are writing off the 280x as a piece of garbage?
That was the problem I had with the 7970 direct CU II it was an awesome card but the 3 slots were a boner killer for me. The new 280x asus direct CU II is now 2 slot.
