The Asus 270 and Asus 270 X have the same price. Which one should I get. I am confused by LinusTechTips, cause he said to go with the 270.
Well go with the 270X the 270X is a 7870GHZ edition. the 270 is a 7870.
for the same price, offcourse go with the 270X its higher clocked at stock. thats the main diffrence.
R9-270X is clocked at 1120mhz, the R9-270 is at 950mhz.
Linus said it is better to go with the 270 as it is basically the same thing for cheaper, however if it is the same price you might as well go for the better one as it guarantees the higher clock speed.
Makes zero differnce if there the same price grab the 270x
Thank you!
