Like @eduncan911 said, custom loop water cooling is the answer for “silent” performance under load, just be aware if you want quiet, inaudible, or undetectable it requires different levels of hardware.
I have a 5950X & 7900XTX on a custom hard loop with a 360mm & 280mm radiator, it is acceptable under light load, kinda noisy under a heavy load.
A 3970X Threadripper with a bitspower 360mm AIO, I just need to spend some time tuning the fan curve because it is kinda annoyingly loud and worse yet it ramps up and down a decent bit. I will probably use a motherboard temperature sensor header and stick a probe in the radiator fins to control AIO fan speed off the radiator temperature.
A 9970X Threadripper with a 140mm, 280mm & 420mm radiator custom EPDM soft loop for just the CPU AND the loudest thing in the case are the R9700 GPUs and the pump when it ramps up, the CPU loop is pretty quiet, but the system isn’t silent.
And a way overkill cooled gaming rig with a 14900k & a 5090 both cooled by a custom EPDM soft loop using 2x 280mm, 2x 240mm & 2x 480mm radiators (12x 120mm Noctua fans & 6x 140mm Noctua fans). It runs essentially inaudible within arms reach under modest load, barely a whisper under really heavy loads.
Other people run one or more MORA external radiators they locate a few or several dozen feet away, possibly in another room even. Those can be a great option if done right.
The point is if you want silent or really quiet operation under load you need a lot of fans running at low RPM moving air across a lot of radiator surface area. Otherwise you are limited by the size of a tower cooler and what it can dissipate (based on it’s fin density, number of heat pipes, ect…) plus how much air the fans can move.
You can also consider modding what you have to work with different fans, if you can design and 3d print things then a fan shroud from your existing tower cooler to a 120mm or 140mm fan could work to move a ton of air and maybe provide more CPU cooling potential while most likely being quieter.
