Quiet card for 2560 x 1600 gaming?
I just upgraded my monitor and as expected, my old card just isn't cutting it.  So I am looking for a new card (I don’t care if it is ATI or nVidia).
Here is what I am looking for:
  • Reasonably priced (I’m not spending $600 on a video card).
  • Quiet.
  • Can drive most games at 30+ FPS with reasonable level of details at 2560 x 1600.
I was looking at the 7970, but from what I hear they are crazy loud and burn a lot of power.
What are your thoughts?  I would really like to hear from anyone running at 2560 x 1600 (or 1440).
Thanks!
You can grab two of these for about the same price as a GTX 770...
http://goo.gl/mBSMHj
They will kick ass at that resolution.  A pair of these would be an even better option if you can spare the cash...
http://goo.gl/MGBN04
Oh, and you also get 3 free games of your choosing with each 7950 you purchase.
[Edit]
I probably should have asked this to begin with.  What are your computer's specs?  You'll obviously need a motherboard and PSU that supports two 7950s.
Thanks!  :)  I have twin 5830’s now, and well, they don’t work.  I have had them for over a year and CrossFire has never worked...  Ever.
So I am VERY weary of trying it again.  Hell, if I could get them working, I bet it would be enough...
I probably should have said that in the first post.
From what I have been hearing, AMD has greatly improved the effectiveness of Crossfire with their most recent drivers.  I'm personally running a GTX 670, so I'm not familiar with it.  I would definitely give it a try though.  If it ends up not working out, you can return 'em. Then you can just check around on Ebay for a couple of GTX 670s.  Or you can avoid it entirely and begin looking around for some GTX 670s now.  It's completely up to you though.
I think AMD is going to be announcing their next gen GPUs on the 25th or 26th.  I keep hearing stuff about it. I'm not sure though.  I'm guessing they are going to release the HD 9000 series in October.
