I've recently noticed that my PC is just too darn noisy, so I'm replacing all the fans, starting with 120mm fans(including PSU).
So I've gotten to the point where I want to replace my 140mm fans, currently I have the Lian Li LED fans that came with the case, and they're not that noisy, but they're not quiet either.
So I would like a recommendation for quiet 140mm fans, they can have LED's, but it's not mandatory.
Thanks in advance!
Braien.
Noctua nf f14s are always a great choice then there are Gelid silent 14s or Corsair af140s
PS i dont think you can change your psu fan tho
I checked the Corsair fan's, but unfortunately they're not available in my country.
And about the PSU fan, oh I can change that, some wirecutting and soldering, I did that on my previous psu, when the fan got wobbly and noisy.
Then Noctuas for you! lol I'm sure there are other choices with better color but I think they are the best fans for noise/perf
I was recommended these fans aswell:
http://www.newegg.com/Product/Product.aspx?Item=N82E16835214031
But since there are no reviews about this fan, it feels kinda not that reliable buy.
Okay, after reading some reviews, I think I'm getting these:
http://www.amazon.com/BitFenix-Spectre-140mm-BFF-SPRO-14025KK-RP-Black/dp/B007OWPBP6
