Quick repair post: "Gaming" Nuc Fan Fix
My fan had degraded to the point of sounding like a loud coffee grinder and it could not last now that it is once again my main desktop. Intel being Intel could not use any old laptop squirrel cage blower, no it must be a specific one that cause 5 time more than the usual others
Fan access is from below:
Undo the 4 philips screws in the corners:
In like Flynn, just 2 Philips head screws and a piece of tape hold the fan in:
The afflicted fan, it has a better cable:
It is really quite a small board, not really any need for it to be a big NUC:
I was going to repaste it… But that on the other side and i forgot the paste:
Angle shot because:
New fan in, it is so quiet, it’s great.
So the process was super easy. 4 screws to get in the bottom of the unit, two screws hold the fan in and just a little tape attaching it to the fins. Undo the screws, unplug the wire, peel off the tape. Then just redo all the in reverse with the new fan.
Very nice indeed, thanks :slight_smile:
So I take it this is basically a modified Notebook fan assembly.
Yeah pretty much. Its an intel NUC 6i7KYK, it is basically all laptop parts anyway, just packaged differently.
