Will a Cooler Master Hyper 212 Evo fit inside a Corsair 200R?
~Will
~Will
Should do. The EVO is 159mm tall and the 200R has a clearance of a bit more then 160mm. Tight fit though.
It will fit, if you dont have a fan in the sidepanel.
Also, I would get the Dark Knight II. Its the same size, and about the same price, but MUCH better performance.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835233029
That cooler is about $20 more than the 212 evo but ill look into it. Thanks for the suggestion!
