Quick Question
Hello, Sorry if this is in the wrong topic, but I was wondering if the Sapphire Radeon HD 7970 3GB Video Card comes with a crossfire bridge. And also I am guessing it is required in order to run a crossfire setup right?
Yeah a crossfire bridge is required to run crossfire there is a place on the card were you will connect it. It also depend on what manufacturer you go with, like I know VTX3D gives cross fire bridges with their cards. I think some ASUS cards do too. You will have to check on the manufacturers website if they do or do not.
Is this what I am looking for CrossFire™ Bridge Interconnect Cable?
If you are looking to crossfire two AMD cards then yes!
Alright thank you for your help Dr. Jetix!
All AMD cards that can crossfire come with bridges.
I have received some brand new cards in the past that have not come with any crossfire bridges so I do not believe this to be true.
Then most. I've never not gotten one.
