After 5+ years its time for my old computer to find a grave.
So, Ive compiled a gaming rig with a 900$ budget and I just wanna know if something is overkill or a bottleneck.
Ive checked alot of builds and comments here so I think its quite alright.
I have storage (2.5" and 3.5"), windows and such.
http://pcpartpicker.com/user/Spectator/saved/D8Hscf
Im swedish so im buying this in Sweden, here is the list at the store im buying from.
100$ more expensive in sweden :(
https://www.komplett.se/k/shoplist.aspx?mode=receive&si=1531515&su=C4202C59-06DF-4840-A09F-01756284E03E
I would recommend a higher wattage power supply. Power supplies are most efficient when at 50% load and that will give you plenty of room if you want to upgrade components in the future. The rest of the build looks good though.
Hy Spectatorn,
I agree with burdebc on the power supply, a 650W will give more headroom and it will allow you to upgrade more easily. I've got a CX430M series PSU and I can vouch for its realiability. Your GPU choice is impeccable and the CPU you choose will be fine for most things. I hope I'm not wrong, but its performance should be comparable to an i5.
All in all, it's a nice PC! If you can get an SSD in there you'd be set :)
Have fun!
