Quick and simple screenshots for discourse and other websites
So I just discovered the win + shift + s shortcut and also that some websites like discourse allow pasting images from the clipboard.
So you can do win + shift + s which will get you the snipping tool functionality, then after taking it will put the image in your clipboard, which then you can ctrl + v in a comment text box which will upload the image and inline it. Github, Gitlab and this site all work.
With this, it literally 5 seconds to upload a screenshot.
Oh, yeah I think you have to have win10 1809 or higher, although older windows 10 version might work but a bit differently.
From the title, I thought you meant something like Vivaldis inbuilt “screenshot whole website”
:ok_hand: Nice. No more win + r + “snip” lol
I just use win+prntscrn key
Used to be labeled the “sys rq” key, this lets the deep state you are up to no good :slight_smile:
You could do this for ages now, though not with a built-in shortcut.
Open Windows menu → find Snipping Tool → Right-click → Properties → Enter a shortcut → Apply → Done
/edit:
You can do this with pretty much any program by the way.
That works if you want to capture the whole screen, just I often don’t want the entire screen but only a portion of it.
Neat, thanks for the info.
