Quick and easy 3D modeling / CAD app for mockups
I want to visualize what a shed would look like in my small back yard. I'm not good at picturing this stuff in my head even though I can mark on the ground where the shed will fit and sit.
I was wondering if there was a quick and easy 3D modelling tool I could use to build a mockup with the measurments I made. So I can move the view point round and visualize it that way. Pref things I use from linux or even webbased. I know of Blender, but that might be over kill for what I need.
You can try and use Sketchup. It's fairly easy. I've modeled my deck to modify it in future.
But I am unaware about any Linux versions of it. So you should try sweethome3d
It was adequate for what it promised.
Yeah, I'mma go with this, SketchUp is the choice for you, OP.
