Install catalyst? I thought we were trying to fix X. <end sarcasm>
I'll give that a try then.
Edit: Trying to install catalyst raises some dependency issues with mesa. Before I throw mesa and all that out, does installing catalyst somehow actually fix the problem, or are we just going around it? Or is it a diagnostic thing?
I used "Xorg :0 -configure" to make an xorg.conf, put that in the right place, and now X starts, but it's just an unresponsive black void with what looks like xterm in the top left corner. It doesn't react to any input from the keyboard or mouse.
Edit: Nevermind, after a quick change to the conf file, the mouse and keyboard are working fine, it just doesn't draw any text.
Looks like it just needs some more configurating. I think I can take it from here. Thanks for the help.
Everything runs almost perfectly. X, Xfce, networking, all the basics. X seems to stall once in a while, I think that's mostly related to Firefox, though.
Zoltan's KVM guide isn't working for me. The libvirtd service doesn't start for some reason. I haven't looked into it much.
I also have a dual-graphics situation that I should probably work out eventually.
Want to know an even easier quicker way? antergos. It installs a pre-configured arch system for you with no need for doing anything yourself except for setting the keyboard layout and time and things like that.
That's no fun. You don't have nearly as much control over how things are configured - you could spend 4 hours installing Arch to your exact liking, with only the absolute most essential modules so that you have one of, if not the most streamlined distro for your needs. Anteragos takes away the connection you have with the internals. Arch lets you know what's going on.
Because I love reinstalling Arch on my laptop. Im going to give antergos a try tonight. If i dont like the way it works (or doesnt work) ill just install arch again.
I have changed USB's changed ports and tried loading different versions on boot. I get to a point where is Press ESC in 5 seconds to skip startup.nsh and whatever I do, It just does nothing.
