Questions regarding screen size
I have a question,what monitor size is the best for average eyefinity gaming?(and some work of course)
What aspect ratio is the best ( 16:9.16:10 ) 16:10 is either 2560x1600,1920x1200 or 1680x1050.
Right now I want to buy three monitor,and I'm most likely never change my display again ( at least in 3-5 years )
I don't need monstrous size like 27",so from a user perspective,what's the most commonly use screen size for single monitor and triple monitor?
around 20"-23" is about right for a triple monitor setup. 16:10 has a few more pixels than 16:9, that's all.
I'm running at 2560x1440 on a 27" monitor - it's got so many pixels I can run facebook side-by-side 2 1/2 times with no problems.
If you are going to go triple just get some 1920x1080 monitors - there is plenty of pixels on here and videos don't really go above 1080p anyway.
22-24" 1080p
Not all games play well with 16:10 and if you ever want to do any recording or anything forget about it.
NOT TO MENTION HOW HARD IT IS TO FIND GOOD 16:10 MONITORS AT A REASONABLE PRICE
sry abt the caops, i don wanna retype it
Ok...23" 1080p monitor then.
a 24" 1920x1200 IPS or PLS panel would be my ideal monitor.
There's nothing wrong with a 16:10 monitor even for gaming.  Not sure why that was brought up at all.  I stream 16:10 aspect games at 720p no problem.  It looks great, actually.
Is AOC monitor good enough?
Currently I have a 18.5" 1366x768 monitor. and 1366x768 monitor at the same size is just $65 here. so....should I get 3 1080p monitor or should I add another two for my current setup?
Extreme 720p is 16:9 meaning your video is stretched.
