Would there be a way to test how much energy is being devoted to the IO dies given that they’re on An older and not as advanced node intel 7. Especially since. The Grand Rapids D is coming out with IO dies on Intel 4. I think in the Rome generation Wendell was talking about the IO die using a lot of power and that as they scaled that down, they were able to devote more power to the cores?
Also. I know Granite Rapids is one dim per channel for the highest memory speeds, but if you Go down in memory speed. Can you do 2 dim per channel?
There should be performance monitoring counters for them, but it might take awhile for software to be updated enough to read them though.
The IO dies shouldn’t be nearly the bottleneck or use as much power as AMD’s because Intel didn’t put the memory controllers on the IO dies which greatly increases memory performance and reduce power consumption;
Preliminary reports are showing GR-AP to have over twice as much memory bandwidth as the top of stack Turin.
Also Intel is using EMIB instead of a normal PCB substrate for chiplet to chiplet communication which reduces power usage.
My understanding is that theoretically GR-AP can do 2DPC, but no motherboard manufactures committed to producing them. There should be GR-SP boards with 2DPC once GR-SP launches though.
It looks like Intel is pretty heavily courting scientific computing folks with granite rapids which is great… but probably also suggests that 1 dimm per channel is here to stay.
