Questions... Android, ubuntu, arm
I got a tablet. A lenovo A1000. Cheap, basic tablet. It's kinda nice and so, but it have one major problem. It's running android by default. After some playing around with it, I came to conclusion that android is not for humans. Since most of my computers run ubuntu, I am wondering if I can install ubuntu on my tablet and be happy with my life again. Thus got some questions:
- did anyone had any luck with such idea?
- can I install android again if ubuntu in tablet will be even worse?
- drivers? ubuntu? tablet? do they exists?
there a ubuntu OS for phones.. but i dont know if it's finished yet. or how you would install it on your tablet. i suggest checking out xda-developers.com to see if anyone has done custom roms for your tablet. might have to find out if maybe there's a base model for your tablet as the same info may apply. good luck.
Ubuntu is possibly the worst variant of Linux, ever.
Now that that is out of the way.
What do you mean by "No meant for humans"?
Also, UbuntuOS is only for Nexus devices, so no.
i was able to install the beta of ubuntuOS on my galaxy s3. so yes, officially for nexus, but if you have the chops you can install it on any arm based phone.
You don't have to use Ubuntu Phone, you can just grab the Ubuntu ARM version, but it doesn't run that well on ARM hardware. If you do want to use it, I would run it in a chroot, using an automated linux installer in Android.
I don't have Google on my phones/tablets, so I use alternative software stores, mainly f-droid and yandex, and on f-droid (which is only FLOSS), you can get Lil'Debian, the automated installer for Debian ARM in a chroot. It's easy to use and runs quite well.
Fastest is to use a custom kernel with Linaro optimizations and a highly optimized Fedora ARM or Arch ARM version, both of these are faster than Debian ARM. In Fedora, the ARM version is a primary architecture since Fedora 20. It's pretty fast and the most full-featured full ARM distro, ideal for tablets, I use it, and it works fine.
If you substitute Android, you can set it back if you have a backup or an image at hand. You need to prepare your device to do stuff to it safely.
