Im looking to do some updates to my Plex setup.
Current Setup
i5 3570K
16 Gigs of Ram
HD7950
500 Gig SATA SSD
Ubuntu 24.04 Desktop
QNAP TS451+ with 8 TB Hard disk (where media is stored)
HDHomeRun
I was learning about Docker and Docker Compose and watched some videos on Dockage. What I looking for is a sanity check, to make sure what I want to do is going to work.
The services Id like to run
- Plex Media Server (I have Plex Pass)
A) Used with Live TV DVR (Transcodes happen when wathcing Live)
B) Need to take recordings and convert them to MP4 to reduce size - Automatic Ripping Machine
A) Will like be using USB optical drives
B) Content will be 1080p or below, Not doing 4K - Arr Stack
A) Sonarr, Radarr, Lidarr, possibly Bazar
B) In the case of Sonarr and Raddar
b) used for renaming content in to Plex friendly names
b) read they can ensure the content gets to proper folders
Do I need to run a separate instance of HandBrake for Plex to use for converting recordings? OR can I somehow pass it along to ARM as Handbrake is a component? The other question I have is CPU, what would I even need? Im OK with used, however I have seen people suggest those Beelink PC’s on Amazon. Also I seen some reports that at least for Intel iGPU’s, you can share its transcoding capabilities between multiple containers, is that correct? I always thought that GPU’s in general got passed thru and the container had exclusive use. As far as the Arr stack is concerned Im not looking to setup the torrenting capabilities. Content will be ripped only from disk or recorded from OTA TV.
