Question regarding ZFS and higher capacity cold spares
I’ve just purchased 2x 18TB disks to act as future, ready to go replacements in the event that my ZFS pool ever suffers a disk failure. The thing is though, I’ve found that I can get 2x 20TB from the same OEM, for a few pounds less.
I don’t envisage ever increasing the vdev’s capacity by replacing and resilvering each disk. So I won’t benefit from the extra 2TB of the 20TB, if they ever end up in the vdev in question. In the short term, I was going to use one or both of the disks as scratch space for a project that requires lots of temporary storage. So the larger disks might benefit me (although I doubt it’d be significant) until they need to be added to my Zpool.
Cancelling my original order and buying the 20TB disks would also be a hassle for reasons I won’t go into. So the question is…
Is there any drawback to using higher capacity replacement disks in a vdev, if you don’t ever intend to grow the vdev?
In short: No problem.
If you replace a 18TB drive with a 20TB drive zfs will just use the first 18TB of the 20TB capacity.
I am not aware of GUI overlays of zfs (aka TrueNAS) handles this.
what Jode said. No problem. Doesn’t even be the same brand or model. Just needs to be a 18T drive or higher.
Slowest drive sets the pace in a RAIDZ vdev. But small differences like 18 vs 20 and same brand doesnt really make a difference.
ZFS just wants to eat block devices and doesn’t care what it is as long as it is 18T.
I run with 16T Toshiba MG08, but pricing on 18-20 is basically the same these days. so I will get 20T drives if I ever need replacement and I will expand the vdevs to 20T if it ends to be even amount of 16T and 20T drives (mirrors).
TrueNAS doesn’t handle that at all. The GUI just calls the standard ZFS utilities when creating the pool (and a pool doesn’t even have to be created within TrueNAS to begin with). The pools are handled by OpenZFS.
TrueNAS is a convenience GUI on top of existing tools, it’s not a ZFS implementation.
I personally partition my drives manually and give ZFS the partitions, so in this case I would just make the partition size the same on the 20TB drive as the 18TB drives when I give it to ZFS, unless I was intending to grow the pool over time to all 20TB drives
