Not really sure which topic to put it under so I put it here.
Now my question--
I'm going to be playing on an HP w1907 18" 1440x900 @ 60Htz.
Would I get better fps in games on that monitor rather a 1080p monitor? I don't have a 1080p monitor but I have a 47" tv and a 20" (both HD 1080p) tv that I will also might play on. Should I play on my HP monitor with a lesser resolution or use my tv with a higher resolution.
you will get higher fps on 1440x900 because you are rendering less pixels if your 20in tv is 1080p that would be the best one to use other wise I dont really like using large tv's for monitors
you will get better fps like ragingh4vok said because it is a smaller image for the graphics card to render. however there will no a loss in quality or detail on a smaller resolution. What ever you prefer.
1920x1080 is 2.07MP
while 144x900 is 1.3MP
MP = megapixels // or the number of individual pixels it has to render.
1080p has 60% more pixels than 1440x900 so if you get 80fps now you should see about 50fps @ 1080p
You will see significantly better fps when using that lower res. and significantly lower fps while using a 1080p screen. But this fps loss gives you a better image.
IIRC, you wanted to purchase a 760? That'd handle 1080p superbly. If you grab a 7950, that'd be good for 1440p too.
I don't think I'll be getting a 1440p monitor anytime soon. :) Thanks though for the help.
Why don't you like using TVs? I'm going to be sitting approx. 8-10' away from the screen.
