Question about headphones
As some of you know I recently acquired a Fiio jm21 dap. Sofa it’s doing a great job for what I wanted it to! I do have a few questions if the audio files will permit me!
The Fiio has an headphone out and a balanced out.
What is the difference between the 2 besides jack size?
Can I easily convert any pair of headphones to a balanced pair?
If not what would you recommend for a set of headphones for the Fiio jm21?
Thank you!
It depends on the design of the amp but generally balanced (really it’s differential, not balanced) will have double the voltage and usually more power and can have a lower noise floor. But it really depends on how the amp is designed.
Any headphone that has separate connectors for each cup can work with a balanced output, you’ll just need an appropriate cable. But a headphone with a shared common neutral won’t work without modification. You need a separate live and neutral wire for each channel to use the balanced output.
Thank you @Dexter_Kane for the information!
Cheers!
