Hello Tek Syndicate!
I was wondering that if I buy an APU to use before buying a discrete graphics card, and if the integrated GPU inside the APU will conflict with the graphics card's compatibility or performance at all.
I was looking into buying an AMD A10-6800K APU for $130 off of Amazon, and was curious of buying a Radeon 7870 or anything like it or better a while after I finish building my to-soon-be-build PC that I haven't both all the parts to yet. So I was wondering, can I run the graphics card at it's indicated quality without suffering from any performance issues with the integrated GPU in the processor?
I think that the GPU inhibiting the x16 speed PCI-Express slot will cancel out the signal from the motherboard to the integrated video, like what my older pre-built store bought computer did when I added a discrete graphics card to it years ago.
Anyway, I hope to get answer soon ahead of time so I'll know what to do when the time comes. I'm sorry if any of the stuff I was saying didn't make sense, because I just got into computer hardware after a friend recommended me into building my PC instead of buying one.
Thanks in advance,
VGam3r97
