Yeah almost exclusively in the terminal. Not often though
Forum for Maximum Shitposting
Now this is a cause I’m ready to support.
Don’t know if I’m essential employee or not but it doesn’t matter if I’m at the office or working form home there’s still too much to do and too little time.
But things I try to or want to focus on:
- Get enough sleep
- Play games and relax after work.
- Exercise at least a little
- Tinker more with AwesomeWM
- Maybe finally start some online Java course from Udemy
- Install ZSH and see what’s the fuss is all about.
I am looking to build a home server, and then L1 just put out a video about “World Backup Day!” Sweet.
Since I am complete retard and bored off my tits I decided to do something completely useless…
I am programing an algorithm for building spaceships…
It’s much less exciting than it sounds.
Still working at home like I was before quarantine.
It’s OK though. My procrastination has been trying to patch the ~45 1-inch holes drilled into the drywall around my house from the dry out process when my house flooded. I’d rather work on work than that.
Personally, my goal is to get through my O’Reilly web development book. I got XAMPP set up on my desktop on Ubuntu 19.10 with no help from the book because it only gets into specifics for macOS and Windows. So far the beginning of the book is all terms and concepts so I’m kinda just breezing through it to get an overview because I won’t remember the specifics anyways.
I’d also like to get into game development a little bit. Just some really simple stuff. I found a website called The 7drl Challenge that I would like to do if I still have time after getting through my book.
Dodged a bullet there
Oh yeah? Watch me!
Realistically I am about to put my media NAS together … on a bench table. Weird, I know. It kinda makes sense, trust me.
I also still have to sell tons of stuff which needs to be photographed, I’ll probably do that first.
for(i = 0; i < sizeof(fptr); i++)
sizeof(fptr)
will be 4 or 8 depending on your architecture, I think what you wanted was the filesize, not the size of *FILE
. See fseek
and ftell
, or stat
Really though if you are reading the entire file you should just loop until fgets
returns EOF
. If you are trying to get a line count which it looks like, you need to first read the entire file and count how many lines there are.
what are you doing to that poor thinkpad?
-edit- nvm, libreboot.
How’d it go?
To transform into a guitar ?
Get my plex server fully loaded.
Yes - roundabout intro when?
Fucking game changer. I never had more than 8 todos in the app. You were right, as soon as I added a 9th it didn’t work.
1 Study C
2 Discrete Mathematics
3 Review Code
4 Be Tony Stark
5 Tell Wendell you love him
6 Exercise
7 Build AdminDevOS
8 Time travel
Added a function to get line count
1 Study C
3 Review Code
4 Be Tony Stark
6 Exercise
7 Build AdminDevOS
8 Time travel
9 Write Supernatural fanfic
[chris@adlabs-server todo]$ ./todo add "Last task"
[chris@adlabs-server todo]$ ./todo list
1 Study C
3 Review Code
4 Be Tony Stark
6 Exercise
7 Build AdminDevOS
8 Time travel
10 Last task
[chris@adlabs-server todo]$ ./todo delete 7
1 Study C
3 Review Code
4 Be Tony Stark
6 Exercise
7 Time travel
8 Write Supernatural fanfic
9 Last task
It’s appalling how much I suck at C but I am appreciative for all the help
You’re on your way
If you never intend to edit the file with a plain text editor I would suggest you use a binary format that has a header with the line count, that way you wouldn’t have to iterate the entire list just to get the number of lines.
You could even go futher, since your todo entries are short, use a fixed length record which would then let you just jump to entries because you can calculate their offsets, and if storing records you could even store some status information, ie.
Note: untested pseudo code written at midnight off the top of my head
#include <stdint.h>
#include <stdio.h>
#define TODO_FILE_VERSION 0x0101 // 1.01
struct ToDoHeader
uint16_t version; // file format version
uint16_t recordCount; // 16-bit, max 65536
#define STATUS_NOT_STARTED 0
#define STATUS_IN_PROGRESS 1
#define STATUS_ON_HOLD 2
#define STATUS_COMPLETED 3
const char * RecordStatusStr[] = {
"Not Started", "In Progress", "On Hold", "Completed" };
struct ToDoRecord
uint8_t status;
char data[256]; // the text, null terminated
void printToDo(uint16_t number)
struct ToDoHeader header;
FILE *fp = fopen("todo.dat", "r");
if (!fp) {
printf("failed to open the file\n");
return;
if (fread(&header, sizeof(header), 1, fp) != 1) {
printf("failed to read the header\n");
fclose(fp);
return;
if (header.version != TODO_FILE_VERSION) {
printf("unsupported file version 0x%04x\n", header.version);
fclose(fp);
return;
if (number >= header.recordCount) {
printf("invalid ToDo number\n");
fclose(fp);
return;
const long int entryOffset = sizeof(struct ToDoRecord) * number;
if (fseek(fp, entryOffset, SEEK_CUR) != 0) {
printf("failed to seek\n");
fclose(fp);
return;
struct ToDoRecord record;
if (fread(&record, sizeof(record), 1, fp) != 1) {
printf("failed to read the record\n");
fclose(fp);
return;
printf("%d. %s (%s)\n", number, record.data, RecordStatusStr[record.status]);
fclose(fp);
I will leave the write functionallity side of this as an excersise for you
not finished yet. went back to work and havent had time. next week probably.
To everyone:
o-okay…
drinks glass of water
