Quadro P2000 Error 43 only when x16 primary slot ?!
Wendell did open my eyes about pcie pass-through and here im trying to make it work.
My hardware is
R9 3900x
Msi x570 mpg gaming plus
gtx 1050ti
quadro p2000
Unfortunately the mb dosen’t have the option to select primary gpu and the second pcie slot is passing thought the chipset. no bifurcation.
I managed to pass a quadro P2000 (on the x4 chipset pcie slot) into the win10 vm (manjaro host) by using this scripts : GitHub - pavolelsig/passthrough_helper_manjaro
It works but looking glass at 1440p bottleneck by the 4GB/s bandwidth (around 30fps)
So i decided to switch the 1050ti from primary to secodary and use the p2000 at full x16.
2 days later still din’t manage to do it so im reaching out for help.
The state im now is that after dumped the p2000 vbios from windows* and passed into the vm i can see image in the uefi tianocore and after the booting of windows starts no more updates in the extrnal display only in the qxl kvm based.
  • after i edit them with a hex editor to remove the nvidia header used for flasing.
In the window manager i get error 43. I thougth to hide the kvm allthought i din’t had to hided when i had the p2000 in the second slot still nothing.
im out of ideas at this point.
this is my logs of the pcie:
00:00.0 0600: 1022:1480
	Subsystem: 1462:7c37
	Flags: fast devsel
00:00.2 0806: 1022:1481
	Subsystem: 1022:1481
	Flags: fast devsel, IRQ 26
	Capabilities: [40] Secure device <?>
	Capabilities: [64] MSI: Enable+ Count=1/4 Maskable- 64bit+
	Capabilities: [74] HyperTransport: MSI Mapping Enable+ Fixed+
	Capabilities: [c8] Vendor Specific Information: Len=18 <?>
00:01.0 0600: 1022:1482
	Flags: fast devsel, IOMMU group 0
00:01.1 0604: 1022:1483 (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 27, IOMMU group 1
	Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
	I/O behind bridge: [disabled]
	Memory behind bridge: fc400000-fc4fffff [size=1M]
	Prefetchable memory behind bridge: [disabled]
	Capabilities: [50] Power Management version 3
	Capabilities: [58] Express Root Port (Slot+), MSI 00
	Capabilities: [a0] MSI: Enable+ Count=1/1 Maskable- 64bit+
	Capabilities: [c0] Subsystem: 1022:1453
	Capabilities: [c8] HyperTransport: MSI Mapping Enable+ Fixed+
	Capabilities: [100] Vendor Specific Information: ID=0001 Rev=1 Len=010 <?>
	Capabilities: [150] Advanced Error Reporting
	Capabilities: [270] Secondary PCI Express
	Capabilities: [2a0] Access Control Services
	Capabilities: [370] L1 PM Substates
	Capabilities: [3c4] Designated Vendor-Specific: Vendor=1022 ID=0001 Rev=1 Len=44 <?>
	Capabilities: [400] Data Link Feature <?>
	Capabilities: [410] Physical Layer 16.0 GT/s <?>
	Capabilities: [440] Lane Margining at the Receiver <?>
	Kernel driver in use: pcieport
00:01.2 0604: 1022:1483 (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 28, IOMMU group 2
	Bus: primary=00, secondary=20, subordinate=2c, sec-latency=0
	I/O behind bridge: 0000c000-0000efff [size=12K]
	Memory behind bridge: f9000000-fa9fffff [size=26M]
	Prefetchable memory behind bridge: 00000000d0000000-00000000e1ffffff [size=288M]
00:02.0 0600: 1022:1482
	Flags: fast devsel, IOMMU group 3
00:03.0 0600: 1022:1482
	Flags: fast devsel, IOMMU group 4
00:03.1 0604: 1022:1483 (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 29, IOMMU group 5
	Bus: primary=00, secondary=2d, subordinate=2d, sec-latency=0
	I/O behind bridge: 0000f000-0000ffff [size=4K]
	Memory behind bridge: fb000000-fc0fffff [size=17M]
	Prefetchable memory behind bridge: 00000000b0000000-00000000c1ffffff [size=288M]
00:04.0 0600: 1022:1482
	Flags: fast devsel, IOMMU group 6
00:05.0 0600: 1022:1482
	Flags: fast devsel, IOMMU group 7
00:07.0 0600: 1022:1482
	Flags: fast devsel, IOMMU group 8
00:07.1 0604: 1022:1484 (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 31, IOMMU group 9
	Bus: primary=00, secondary=2e, subordinate=2e, sec-latency=0
	Memory behind bridge: [disabled]
	Capabilities: [58] Express Root Port (Slot-), MSI 00
	Capabilities: [c0] Subsystem: 1022:1484
00:08.0 0600: 1022:1482
	Flags: fast devsel, IOMMU group 10
00:08.1 0604: 1022:1484 (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 32, IOMMU group 11
	Bus: primary=00, secondary=2f, subordinate=2f, sec-latency=0
	Memory behind bridge: fc200000-fc3fffff [size=2M]
00:14.0 0c05: 1022:790b (rev 61)
	Flags: 66MHz, medium devsel, IOMMU group 12
	Kernel driver in use: piix4_smbus
	Kernel modules: i2c_piix4, sp5100_tco
00:14.3 0601: 1022:790e (rev 51)
	Flags: bus master, 66MHz, medium devsel, latency 0, IOMMU group 12
00:18.0 0600: 1022:1440
	Flags: fast devsel, IOMMU group 13
00:18.1 0600: 1022:1441
00:18.2 0600: 1022:1442
00:18.3 0600: 1022:1443
	Kernel driver in use: zenpower
	Kernel modules: k10temp, zenpower
00:18.4 0600: 1022:1444
00:18.5 0600: 1022:1445
00:18.6 0600: 1022:1446
00:18.7 0600: 1022:1447
01:00.0 0108: 1987:5012 (rev 01) (prog-if 02 [NVM Express])
	Subsystem: 1987:5012
	Flags: bus master, fast devsel, latency 0, IRQ 43, NUMA node 0, IOMMU group 14
	Memory at fc400000 (64-bit, non-prefetchable) [size=16K]
	Capabilities: [80] Express Endpoint, MSI 00
	Capabilities: [d0] MSI-X: Enable+ Count=9 Masked-
	Capabilities: [e0] MSI: Enable- Count=1/8 Maskable- 64bit+
	Capabilities: [f8] Power Management version 3
	Capabilities: [100] Latency Tolerance Reporting
	Capabilities: [110] L1 PM Substates
	Capabilities: [128] Alternative Routing-ID Interpretation (ARI)
	Capabilities: [200] Advanced Error Reporting
	Capabilities: [300] Secondary PCI Express
	Kernel driver in use: nvme
20:00.0 0604: 1022:57ad (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 24, IOMMU group 15
	Bus: primary=20, secondary=21, subordinate=2c, sec-latency=0
	Capabilities: [58] Express Upstream Port, MSI 00
	Capabilities: [a0] MSI: Enable- Count=1/1 Maskable- 64bit+
21:00.0 0604: 1022:57a3 (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 33, IOMMU group 16
	Bus: primary=21, secondary=22, subordinate=22, sec-latency=0
	Memory behind bridge: fa900000-fa9fffff [size=1M]
	Capabilities: [58] Express Downstream Port (Slot+), MSI 00
21:01.0 0604: 1022:57a3 (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 34, IOMMU group 17
	Bus: primary=21, secondary=23, subordinate=23, sec-latency=0
	I/O behind bridge: 0000e000-0000efff [size=4K]
	Memory behind bridge: f9000000-fa0fffff [size=17M]
21:04.0 0604: 1022:57a3 (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 35, IOMMU group 18
	Bus: primary=21, secondary=26, subordinate=26, sec-latency=0
	I/O behind bridge: 0000d000-0000dfff [size=4K]
	Memory behind bridge: fa800000-fa8fffff [size=1M]
21:05.0 0604: 1022:57a3 (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 36, IOMMU group 19
	Bus: primary=21, secondary=27, subordinate=27, sec-latency=0
	I/O behind bridge: 0000c000-0000cfff [size=4K]
	Memory behind bridge: fa700000-fa7fffff [size=1M]
21:06.0 0604: 1022:57a3 (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 37, IOMMU group 20
	Bus: primary=21, secondary=28, subordinate=28, sec-latency=0
	Memory behind bridge: fa600000-fa6fffff [size=1M]
21:08.0 0604: 1022:57a4 (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 38, IOMMU group 21
	Bus: primary=21, secondary=2a, subordinate=2a, sec-latency=0
	Memory behind bridge: fa200000-fa3fffff [size=2M]
	Capabilities: [58] Express Downstream Port (Slot-), MSI 00
21:09.0 0604: 1022:57a4 (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 40, IOMMU group 22
	Bus: primary=21, secondary=2b, subordinate=2b, sec-latency=0
	Memory behind bridge: fa500000-fa5fffff [size=1M]
21:0a.0 0604: 1022:57a4 (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 42, IOMMU group 23
	Bus: primary=21, secondary=2c, subordinate=2c, sec-latency=0
	Memory behind bridge: fa400000-fa4fffff [size=1M]
22:00.0 0108: 15b7:5009 (rev 01) (prog-if 02 [NVM Express])
	Subsystem: 15b7:5009
	Flags: bus master, fast devsel, latency 0, IRQ 24, NUMA node 0, IOMMU group 24
	Memory at fa900000 (64-bit, non-prefetchable) [size=16K]
	Memory at fa904000 (64-bit, non-prefetchable) [size=256]
	Capabilities: [80] Power Management version 3
	Capabilities: [90] MSI: Enable- Count=1/32 Maskable- 64bit+
	Capabilities: [b0] MSI-X: Enable+ Count=17 Masked-
	Capabilities: [c0] Express Endpoint, MSI 00
	Capabilities: [100] Advanced Error Reporting
	Capabilities: [150] Device Serial Number 00-00-00-00-00-00-00-00
	Capabilities: [1b8] Latency Tolerance Reporting
	Capabilities: [900] L1 PM Substates
23:00.0 0300: 10de:1c82 (rev a1) (prog-if 00 [VGA controller])
	Subsystem: 1458:378e
	Flags: bus master, fast devsel, latency 0, IRQ 126, IOMMU group 25
	Memory at f9000000 (32-bit, non-prefetchable) [size=16M]
	Memory at d0000000 (64-bit, prefetchable) [size=256M]
	Memory at e0000000 (64-bit, prefetchable) [size=32M]
	I/O ports at e000 [size=128]
	Expansion ROM at fa000000 [virtual] [disabled] [size=512K]
	Capabilities: [60] Power Management version 3
	Capabilities: [68] MSI: Enable+ Count=1/1 Maskable- 64bit+
	Capabilities: [78] Express Legacy Endpoint, MSI 00
	Capabilities: [100] Virtual Channel
	Capabilities: [250] Latency Tolerance Reporting
	Capabilities: [128] Power Budgeting <?>
	Capabilities: [420] Advanced Error Reporting
	Capabilities: [600] Vendor Specific Information: ID=0001 Rev=1 Len=024 <?>
	Capabilities: [900] Secondary PCI Express
	Kernel driver in use: nvidia
	Kernel modules: nouveau, nvidia_drm, nvidia
23:00.1 0403: 10de:0fb9 (rev a1)
	Flags: bus master, fast devsel, latency 0, IRQ 41, IOMMU group 25
	Memory at fa080000 (32-bit, non-prefetchable) [size=16K]
	Capabilities: [68] MSI: Enable- Count=1/1 Maskable- 64bit+
	Capabilities: [78] Express Endpoint, MSI 00
	Kernel driver in use: snd_hda_intel
	Kernel modules: snd_hda_intel
26:00.0 0106: 1b21:0612 (rev 02) (prog-if 01 [AHCI 1.0])
	Subsystem: 1b21:1060
	Flags: bus master, fast devsel, latency 0, IRQ 105, IOMMU group 26
	I/O ports at d050 [size=8]
	I/O ports at d040 [size=4]
	I/O ports at d030 [size=8]
	I/O ports at d020 [size=4]
	I/O ports at d000 [size=32]
	Memory at fa800000 (32-bit, non-prefetchable) [size=512]
	Capabilities: [50] MSI: Enable+ Count=1/1 Maskable- 64bit-
	Capabilities: [78] Power Management version 3
	Capabilities: [80] Express Legacy Endpoint, MSI 00
	Kernel driver in use: ahci
	Kernel modules: ahci
27:00.0 0200: 10ec:8168 (rev 15)
	Flags: bus master, fast devsel, latency 0, IRQ 39, IOMMU group 27
	I/O ports at c000 [size=256]
	Memory at fa704000 (64-bit, non-prefetchable) [size=4K]
	Memory at fa700000 (64-bit, non-prefetchable) [size=16K]
	Capabilities: [40] Power Management version 3
	Capabilities: [50] MSI: Enable- Count=1/1 Maskable- 64bit+
	Capabilities: [70] Express Endpoint, MSI 01
	Capabilities: [b0] MSI-X: Enable+ Count=4 Masked-
	Capabilities: [140] Virtual Channel
	Capabilities: [160] Device Serial Number 01-00-00-00-68-4c-e0-00
	Capabilities: [170] Latency Tolerance Reporting
	Capabilities: [178] L1 PM Substates
	Kernel driver in use: r8169
	Kernel modules: r8169
28:00.0 0108: 15b7:5009 (rev 01) (prog-if 02 [NVM Express])
	DeviceName: RTL8111EPV
	Flags: bus master, fast devsel, latency 0, IRQ 41, NUMA node 0, IOMMU group 28
	Memory at fa600000 (64-bit, non-prefetchable) [size=16K]
	Memory at fa604000 (64-bit, non-prefetchable) [size=256]
2a:00.0 1300: 1022:1485
	Subsystem: 1022:1485
	Flags: bus master, fast devsel, latency 0, IOMMU group 21
	Capabilities: [48] Vendor Specific Information: Len=08 <?>
	Capabilities: [64] Express Endpoint, MSI 00
2a:00.1 0c03: 1022:149c (prog-if 30 [XHCI])
	Subsystem: 1022:1486
	Flags: bus master, fast devsel, latency 0, IRQ 87, IOMMU group 21
	Memory at fa300000 (64-bit, non-prefetchable) [size=1M]
	Kernel driver in use: xhci_hcd
	Kernel modules: xhci_pci
2a:00.3 0c03: 1022:149c (prog-if 30 [XHCI])
	Subsystem: 1022:148c
	Flags: bus master, fast devsel, latency 0, IRQ 41, IOMMU group 21
	Memory at fa200000 (64-bit, non-prefetchable) [size=1M]
	Capabilities: [a0] MSI: Enable- Count=1/8 Maskable- 64bit+
	Capabilities: [c0] MSI-X: Enable+ Count=8 Masked-
2b:00.0 0106: 1022:7901 (rev 51) (prog-if 01 [AHCI 1.0])
	Subsystem: 1022:7901
	Flags: bus master, fast devsel, latency 0, IRQ 106, IOMMU group 22
	Memory at fa500000 (32-bit, non-prefetchable) [size=2K]
	Capabilities: [a0] MSI: Enable+ Count=1/16 Maskable- 64bit+
	Capabilities: [d0] SATA HBA v1.0
2c:00.0 0106: 1022:7901 (rev 51) (prog-if 01 [AHCI 1.0])
	Flags: bus master, fast devsel, latency 0, IRQ 107, IOMMU group 23
	Memory at fa400000 (32-bit, non-prefetchable) [size=2K]
	Capabilities: [a0] MSI: Enable+ Count=16/16 Maskable- 64bit+
2d:00.0 0300: 10de:1c30 (rev a1) (prog-if 00 [VGA controller])
	Subsystem: 103c:11b3
	Flags: fast devsel, IRQ 49, IOMMU group 29
	Memory at fb000000 (32-bit, non-prefetchable) [size=16M]
	Memory at b0000000 (64-bit, prefetchable) [size=256M]
	Memory at c0000000 (64-bit, prefetchable) [size=32M]
	I/O ports at f000 [size=128]
	Expansion ROM at 000c0000 [disabled] [size=128K]
	Kernel driver in use: vfio-pci
2d:00.1 0403: 10de:10f1 (rev a1)
	Flags: fast devsel, IRQ 51, IOMMU group 29
	Memory at fc080000 (32-bit, non-prefetchable) [size=16K]
2e:00.0 1300: 1022:148a
	Subsystem: 1022:148a
	Flags: bus master, fast devsel, latency 0, IOMMU group 30
2f:00.0 1300: 1022:1485
	Flags: bus master, fast devsel, latency 0, IOMMU group 31
2f:00.3 0c03: 1022:149c (prog-if 30 [XHCI])
	Flags: bus master, fast devsel, latency 0, IRQ 96, IOMMU group 32
	Memory at fc200000 (64-bit, non-prefetchable) [size=1M]
	Capabilities: [370] Transaction Processing Hints
2f:00.4 0403: 1022:1487
	Subsystem: 1462:ec37
	Flags: bus master, fast devsel, latency 0, IRQ 44, IOMMU group 33
	Memory at fc300000 (32-bit, non-prefetchable) [size=32K]
kvm xml:
<domain type="kvm">
  <name>win10</name>
  <uuid>7f83a89c-f715-40cf-b654-63bd6c26b344</uuid>
  <metadata>
    <libosinfo:libosinfo xmlns:libosinfo="http://libosinfo.org/xmlns/libvirt/domain/1.0">
      <libosinfo:os id="http://microsoft.com/win/10"/>
    </libosinfo:libosinfo>
  </metadata>
  <memory unit="KiB">33157120</memory>
  <currentMemory unit="KiB">33157120</currentMemory>
  <memoryBacking>
    <hugepages/>
  </memoryBacking>
  <vcpu placement="static">12</vcpu>
  <cputune>
    <vcpupin vcpu="0" cpuset="18"/>
    <vcpupin vcpu="1" cpuset="9"/>
    <vcpupin vcpu="2" cpuset="20"/>
    <vcpupin vcpu="3" cpuset="10"/>
    <vcpupin vcpu="4" cpuset="22"/>
    <vcpupin vcpu="5" cpuset="11"/>
    <vcpupin vcpu="6" cpuset="12"/>
    <vcpupin vcpu="7" cpuset="6"/>
    <vcpupin vcpu="8" cpuset="14"/>
    <vcpupin vcpu="9" cpuset="7"/>
    <vcpupin vcpu="10" cpuset="16"/>
    <vcpupin vcpu="11" cpuset="8"/>
  </cputune>
  <os>
    <type arch="x86_64" machine="pc-q35-5.2">hvm</type>
    <loader readonly="yes" type="pflash">/usr/share/edk2-ovmf/x64/OVMF_CODE.fd</loader>
    <nvram>/var/lib/libvirt/qemu/nvram/win10_VARS.fd</nvram>
    <bootmenu enable="yes"/>
  </os>
  <features>
    <acpi/>
    <apic/>
    <hyperv>
      <relaxed state="on"/>
      <vapic state="on"/>
      <spinlocks state="on" retries="8191"/>
    </hyperv>
    <vmport state="off"/>
  </features>
  <cpu mode="host-model" check="partial">
    <topology sockets="1" dies="1" cores="6" threads="2"/>
  </cpu>
  <clock offset="localtime">
    <timer name="rtc" tickpolicy="catchup"/>
    <timer name="pit" tickpolicy="delay"/>
    <timer name="hpet" present="no"/>
    <timer name="hypervclock" present="yes"/>
  </clock>
  <on_poweroff>destroy</on_poweroff>
  <on_reboot>restart</on_reboot>
  <on_crash>destroy</on_crash>
  <pm>
    <suspend-to-mem enabled="no"/>
    <suspend-to-disk enabled="no"/>
  </pm>
  <devices>
    <emulator>/usr/bin/qemu-system-x86_64</emulator>
    <controller type="usb" index="0" model="qemu-xhci" ports="15">
      <address type="pci" domain="0x0000" bus="0x02" slot="0x00" function="0x0"/>
    </controller>
    <controller type="sata" index="0">
      <address type="pci" domain="0x0000" bus="0x00" slot="0x1f" function="0x2"/>
    </controller>
    <controller type="pci" index="0" model="pcie-root"/>
    <controller type="pci" index="1" model="pcie-root-port">
      <model name="pcie-root-port"/>
      <target chassis="1" port="0x10"/>
      <address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x0" multifunction="on"/>
    </controller>
    <controller type="pci" index="2" model="pcie-root-port">
      <target chassis="2" port="0x11"/>
      <address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x1"/>
    </controller>
    <controller type="pci" index="3" model="pcie-root-port">
      <target chassis="3" port="0x12"/>
      <address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x2"/>
    </controller>
    <controller type="pci" index="4" model="pcie-root-port">
      <target chassis="4" port="0x13"/>
      <address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x3"/>
    </controller>
    <controller type="pci" index="5" model="pcie-root-port">
      <target chassis="5" port="0x14"/>
      <address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x4"/>
    </controller>
    <controller type="pci" index="6" model="pcie-root-port">
      <target chassis="6" port="0x15"/>
      <address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x5"/>
    </controller>
    <controller type="pci" index="7" model="pcie-root-port">
      <target chassis="7" port="0x16"/>
      <address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x6"/>
    </controller>
    <controller type="pci" index="8" model="pcie-root-port">
      <target chassis="8" port="0x17"/>
      <address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x7"/>
    </controller>
    <controller type="pci" index="9" model="pcie-root-port">
      <target chassis="9" port="0x18"/>
      <address type="pci" domain="0x0000" bus="0x00" slot="0x03" function="0x0"/>
    </controller>
    <controller type="pci" index="10" model="pcie-to-pci-bridge">
      <model name="pcie-pci-bridge"/>
      <address type="pci" domain="0x0000" bus="0x08" slot="0x00" function="0x0"/>
    </controller>
    <controller type="virtio-serial" index="0">
      <address type="pci" domain="0x0000" bus="0x03" slot="0x00" function="0x0"/>
    </controller>
    <interface type="bridge">
      <mac address="52:54:00:05:78:e7"/>
      <source bridge="bridge0"/>
      <model type="e1000e"/>
      <address type="pci" domain="0x0000" bus="0x01" slot="0x00" function="0x0"/>
    </interface>
    <serial type="pty">
      <target type="isa-serial" port="0">
        <model name="isa-serial"/>
      </target>
    </serial>
    <console type="pty">
      <target type="serial" port="0"/>
    </console>
    <channel type="spicevmc">
      <target type="virtio" name="com.redhat.spice.0"/>
      <address type="virtio-serial" controller="0" bus="0" port="2"/>
    </channel>
    <input type="mouse" bus="ps2"/>
    <input type="keyboard" bus="ps2"/>
    <graphics type="spice" autoport="yes">
      <listen type="address"/>
      <image compression="off"/>
    </graphics>
    <sound model="ich9">
      <address type="pci" domain="0x0000" bus="0x00" slot="0x1b" function="0x0"/>
    </sound>
    <video>
      <model type="qxl" ram="65536" vram="65536" vgamem="16384" heads="1" primary="yes"/>
      <address type="pci" domain="0x0000" bus="0x00" slot="0x01" function="0x0"/>
    </video>
    <hostdev mode="subsystem" type="pci" managed="yes">
      <source>
        <address domain="0x0000" bus="0x28" slot="0x00" function="0x0"/>
      </source>
      <boot order="1"/>
      <address type="pci" domain="0x0000" bus="0x05" slot="0x00" function="0x0"/>
    </hostdev>
      <source>
        <address domain="0x0000" bus="0x2d" slot="0x00" function="0x0"/>
      </source>
      <rom file="/home/user/Documents/Dumps/p2000_win_e.rom"/>
      <address type="pci" domain="0x0000" bus="0x04" slot="0x00" function="0x0"/>
    </hostdev>
      <source>
        <address domain="0x0000" bus="0x2d" slot="0x00" function="0x1"/>
      </source>
      <address type="pci" domain="0x0000" bus="0x06" slot="0x00" function="0x0"/>
    </hostdev>
    <memballoon model="virtio">
      <address type="pci" domain="0x0000" bus="0x07" slot="0x00" function="0x0"/>
    </memballoon>
    <shmem name="looking-glass">
      <model type="ivshmem-plain"/>
      <size unit="M">64</size>
      <address type="pci" domain="0x0000" bus="0x00" slot="0x0b" function="0x0"/>
    </shmem>
    <shmem name="scream-ivshmem">
      <size unit="M">2</size>
      <address type="pci" domain="0x0000" bus="0x0a" slot="0x01" function="0x0"/>
    </shmem>
  </devices>
</domain>
/etc/default/grub
GRUB_DEFAULT=“saved”
GRUB_TIMEOUT=“4”
GRUB_TIMEOUT_STYLE=“menu”
GRUB_DISTRIBUTOR=“Manjaro”
GRUB_CMDLINE_LINUX_DEFAULT=""
GRUB_CMDLINE_LINUX=“amd_iommu=on rd.driver.pre=vfio-pci kvm.ignore_msrs=1 vfio-pci.ids=10de:1c30,10de:10f1 video=vesafb:off,efifb:off pci=realloc”
/sbin/vfio-pci-override.sh
#!/bin/sh
echo “vfio-pci” > /sys/bus/pci/devices/0000:2d:00.0/driver_override
echo “vfio-pci” > /sys/bus/pci/devices/0000:2d:00.1/driver_override
modprobe -i vfio-pci
/etc/modprobe.d/vfio.conf
install vfio-pci /usr/bin/vfio-pci-override.sh
options vfio-pci disable_vga=1 allow_unsafe_interrupts=1
/etc/mkinitcpio.conf
MODULES=“vfio_pci vfio vfio_iommu_type1 vfio_virqfd”
BINARIES=()
FILES="/usr/bin/vfio-pci-override.sh"
HOOKS=“base vfio udev autodetect modconf block keyboard keymap filesystems”
/etc/modules-load.d/modules.conf
vfio
vfio_iommu_type1
vfio_pci
kvm
kvm_amd
/etc/initcpio/hooks/vfio
#!/usr/bin/bash
run_hook() {
msg “:: Triggering vfio-pci overrided indeed”
/bin/sh /usr/bin/vfio-pci-override.sh
/etc/initcpio/install
#!/bin/bash
build() {
add_file /usr/bin/vfio-pci-override.sh
add_runscript
Doubtful the x4 is bottlenecking you, I ran a hd 7950 off a 1x 2.0 bus with no difference vs 16x 3.0
Your p2000 will need much less bandwidth than say a 1080
Nvidia now supports resizable bar, so if your mobo and CPU supports that with a bios update that will help with code 43
It probably has more to do with going through the chipset and maybe a plx chip than the amount of lanes, it takes a latency hit
i discuss this today on the looking glass discord, It’s actually the case tha the 4Gb/s bandwidth is not enough for 1440p.
original message:
for 4xpcie3.0 you get around 4GB/s , my max frame buffer for 1440p is 29MB so for 60 fps → 60 * (29* 2) = 3480 MB/S so near maxing out the pcie bus (i did the calcultation with 2 frames copied im not sure if that’s correct, otherwise is half that) and ofcourse the gpu needs bandwidth for the games as well so … i guess i will still have to figure out a way to use the quadro in the top slot
i just installed the 465 driver into the vm no difference, i pressure the code 43 this time it means actual problem
Have you enabled resizable bar in bios
Looks like you need a updated Vbios as well
This is not the problem and this is for the 3000 series only, i only needed to see if the error 43 is coming from the driver lock or something is wrong.
The problem is probably in something i do. This should work with a quadro with out error 43 . Maybe something i posted here is not correct.
They’re back porting it all the way back to kepler, so you won’t get code 43 on your 1050ti is why I was posting
No idea on the quadro
update:
i hided the kvm with :
  <features>
    <acpi/>
    <apic/>
    <hyperv>
      <vendor_id state="on" value="whatever"/>
    </hyperv>
    <kvm>
      <hidden state="on"/>
    </kvm>
    <ioapic driver="kvm"/>
  </features>
allocate the audio and video of the gpu in the same bus
<address type="pci" domain="0x0000" bus="0x2d" slot="0x00" function="0x0" multifunction="on"/>
<address type="pci" domain="0x0000" bus="0x2d" slot="0x00" function="0x1"/>
removed the qxl video adapter
and it’s now the quadro displaying image thought the screen that’s connected but still it says (error 43).
update:
I put the computer to sleep for a couple minutes and tried to wake it up to see if running the vm after sleep makes any difference. Nope.
I put the computer to sleep for a couple minutes and then removed the card from the slot for 1 minute and the put it back wake and run the vm to see if will makes any difference. Nope.
Dumping the vbios under linux gived me the same hash before pulling out and after.
edit actual it seems that it dosen’t read the gpu since i complete removed it and still give me the same dump
edit 2
i started the pc with out the quadro and put it when it finish booting in sleep mode. it not show up in the pcie devices so this path lead nowhere.
Still nothing. Im sure we have the right talent in this forum to solve this problem. Any suggestions ?
Edit: Sorry, I just realised I necro’d this thread, another post was made and deleted which brought this to the surface.
How is this going to help things? Now your other GPU is bandwidth limited. Both GPUs need to have enough bandwidth, not just one.
Looking Glass is copying full frames of data across the bus, it’s not your typical desktop/gaming usage/bandwidth.
Error 43 is just a general failure to initialise error, it can mean many things. The most common cause is the nvidia driver detecting you’re in a VM, but it’s also known to happen if you give the VM the GPU bios which is UEFI and have not used the romparser and dd to pull out the part you need.
As for newer drivers being VM friendly, it’s only partially true. While yes they will no longer code 43 due to being in a VM, they still cripple some GPU features, such as custom resolutions which is quite important for Looking Glass users that use a HDMI dummy plug that doesn’t report the resoltuion/refresh rate they wish to use.
