The title says it all, but I’m building a new rig, so to speak, and I’m going to have some serious cooling issues, so I’ve been on the lookout for possible solution, one of which requires a quadruple 80mm radiator. That size limitations are of course due to space constraints
However, I have so far been unable to find any such solution.
As I’ve never been into water cooling as such, it may just be that I’ve been looking in the wrong places, though my googling skills are pretty outstanding.
In any case, if such a product does exist, I’d be very grateful for a kick in the right direction, and if not, may it be possible to custom order what I need somewhere?
I know alpha cool makes 80mm rads. I don’t remember if they make a 4x but I know for sure they make a 3x.
Edit: So I did some digging. Found 1 4x80mm on Alibaba… yikes. So bulk orders only. Cant find anyone who is reselling that. I wouldn’t even trust that radiator anyways. I think your best bet is two of Alphacool’s 2x80 or just one of their 3x80 if thats enough for what you need.
Ya, I’ve considered two 2x80, I just don’t think I have the room to connect them. In fact I may not even have room for the radiators.
Anyway, the most important point was to ensure that I didn’t miss anything obvious.
When I actually get my hardware I’ll know more.
