QNAP TL-D800C questions
Hi,
I’m thinking about buying a TL-D800C(USB) to plug it to a PC running Windows 10, and after reading a lot of forums and watching many YouTube videos, I’ve still got some questions about this QNAP DAS model:
  1. If I plug it to a Windows 10 PC, does it appear in the safe removal tray icon?
  2. If so, will I be able to safely remove (pressing the trayicon) each of the 8 drives individually?
  3. Can I access the SMART data for each drive with 3rd party tools like Crystal DiskInfo?
  4. If a drive is not used for a while, will it go to sleep individually?
  5. If so, how long does a drive have to be without any activity to spin itself down and hibernate?
  6. Do all drives turn on at the same time when the DAS unit boots up?
  7. If not, which order do they follow?
Does any one in this forum have this QNAP DAS model and can shed some light, please?
Thank you very much.
Yes.
In JBOD mode should be exposing each drive so you’ll be seeing 8 removable drives unless you set up some kind of redundant storage through Windows or a toggle on the device.
Yes.
Depends on your Windows power saving settings. There’s spin down time you decide. Can’t recall the Windows default at the moment.
Depends on the OS logic I think. The DAS should allow for all 8 of them to spin up at once but if you want a staggered spin up you need to cconfigure your system for it.
I don’t, I’m going by general knowledge of DAS appliances.
I have this DAS, and its been working perfectly for almost 2 years now.
Just some extra info for you, if you still need it.
First download and install QNAP JBOD Manager.
https://www.qnap.com/en/utilities/essentials
Then plug in your DAS. Power on. Then plug in each drive so they are detected in windows 10.
If you decide to prepopulate the drives, it wont detect any of them.
The drives show up in USB and can be unmounted, but the QNAP software will still say the drive is inserted. And will complain when remove.
I use the unmount from the QNAP software, just to be safe.
Yes, works perfectly.
I have found power nap or sleeping is a bad idea. The drives drop out and don’t tend to come back online unless the unit is powered off or the drives are reinserted.
I personally turn off power saving on USB ports, and turn off sleep mode in windows.
Something to note. If you are using software to read/wright files, some apps will freak out. Jellyfin is one of them.
I found sharing the drive using samba, and then mapping the drive to a drive letter stopped these issues.
I have not tried mapping a share to a folder.
Hope this helps shed some light on this device.
Hey I own a TL D800C hooked up to my Win10 rig. Solid unit so far.
Yes it shows up in the safe removal tray as a USB mass storage device.
You can safely remove individual drives via the tray icon. Just right-click the specific one. CrystalDiskInfo works great. It detects each drive separately for SMART stats.
Drives do spin down individually if idle. Default is about 10-15 minutes of no activity before they hibernate. You can tweak power settings in Windows. They all spin up together on boot. No staggered start.N/A since they sync up. If one’s delayed, it is usually a drive fault.
