Go easy on me here…
I don’t own anything QNAP but I’m right in thinking this isn’t an upgrade option for any old PC right?
http://shop.qnap.com/index.php?route=product/product&keyword=QM2&product_id=215
It would be an awesome purchase if it could work on my server.
Thanks
Sorry, can’t help, but saw one of those on YT with a RJ45 10gbe port.
Never pulled the trigger though
Yes, that was the one I thought I had linked. Fixed the link now though. I would love to know if it would work becasue it’s such a tidy set up.Thanks
oO.o
October 16, 2017, 4:27pm
4
QNAP is most likely rebranding a card made by someone else. Try to find the original manufacturer and buy that. The QNAP one might have custom firmware that could cause you problems.
Also, I would stay away from QNAP in general.
Thanks man. I’ll keep digging.
