I have a few systems (workstations and servers) that I use to run multiple QEMU virtual machines for various purposes, all but one experience the same issue. When using a virtual network device for the guest, whether it be user mode or a tap interface, the guest will freeze for several seconds at a time with high network load. This can sometimes disconnect the VM from the network for a minute or more. Some of these systems run Debian, OpenSUSE, and ArchLinux all of varying versions. The only system that does not experience this problem is a Debian 9 system with a single integrated Realtek NIC, all other systems use Intel NICs. Unfortunately I do not have access to this system to help diagnose my issue as it is a former client 's system.
Does anyone have experience with QEMU virtual network devices and/or Linux tap interfaces and have suggestions on how to improve this issue?
Workarounds that I use:
Cap network bandwidth
Use a physical NIC via vfio for each VM that needs high network bandwidth, this completely solves the issue but it not a practical solution for most of my use cases.
Remedies I have tried that have little or no improvment:
QEMU I/O and vCPU thread isolation
Realtime Linux kernel with Realtime process priority
QEMU I/O and vCPU thread affinity pinning
Using virtio device model and guest driver
Every virtual network device model experiences the same problem
Using Message Signaled Interrupt mode for virtual NIC on guest
Try multiple guest OSes, issue present in Windows, Linux, MacOS, etc.
Try multiple host OSes, Issue present on all Linux Distros I have tried
Try multiple versions of QEMU
Disabling bonded network and using a single NIC
Using only 1 tap interface
Restrict VM to a single memory node and CPU
Using hugepages for QEMU VMs and memory preallocation
Removing dedicated router from network and using the host to route network traffic
Trying various MTU sizes
And more…
The /etc/network/interfaces configuration of one of my Debian 9 servers that experiences this problem. 4 bonded NICs that are bridged to the tap interfaces.
source /etc/network/interfaces.d/*
auto lo
iface lo inet loopback
allow-hotplug enp7s0
auto enp7s0
iface enp7s0 inet manual
bond-master bond0
allow-hotplug enp8s0
auto enp8s0
iface enp8s0 inet manual
bond-master bond0
allow-hotplug enp131s0f0
auto enp131s0f0
iface enp131s0f0 inet manual
bond-master bond0
allow-hotplug enp131s0f1
auto enp131s0f1
iface enp131s0f1 inet manual
bond-master bond0
iface bond0 inet manual
bond-mode 0
bond-miimon 150
bond-downdelay 300
bond-updelay 300
allow-hotplug tap0
allow-hotplug tap1
allow-hotplug tap2
allow-hotplug tap3
allow-hotplug tap4
allow-hotplug tap5
allow-hotplug tap6
allow-hotplug tap7
allow-hotplug tap8
allow-hotplug tap9
auto br0
iface br0 inet static
pre-up ip link set bond0 up
bridge_ports bond0 tap0 tap1 tap2 tap3 tap4 tap5 tap6 tap7 tap8 tap9
bridge_stp on
bridge_maxwait 0
bridge_fd 0
hwaddress ether bc:ef:7b:03:32:21
address 10.0.0.100
netmask 255.255.255.0
network 10.0.0.0
gateway 10.0.0.1
A simplified version of a worstation’s Windows 10 dGPU VM launch script.
#!/bin/bash
sync; echo 1 > /proc/sys/vm/drop_caches
echo 12 > /sys/devices/system/node/node1/hugepages/hugepages-1048576kB/nr_hugepages
sleep 3
MEM=$(cat /sys/devices/system/node/node1/hugepages/hugepages-1048576kB/free_hugepages)
# clear options
OPTS=""
# vm name
NAME="WIN10"
# CPU topology configuration
HOST_CPU_THREADS="8,24,9,25,10,26,11,27,12,28,13,29,14,30,15,31"
# qemu options
OPTS="$OPTS -name $NAME,debug-threads=on"
OPTS="$OPTS -serial none"
OPTS="$OPTS -parallel none"
OPTS="$OPTS -nodefaults"
OPTS="$OPTS -enable-kvm"
OPTS="$OPTS -cpu host,kvm=off,hv_time,hv_vendor_id=null,hv_relaxed,hv_vapic,hv_spinlocks=0x1fff,pmu=off"
OPTS="$OPTS -smp 16,cores=8,sockets=1,threads=2"
OPTS="$OPTS -m $MEM\G"
OPTS="$OPTS -mem-path /dev/hugepages"
OPTS="$OPTS -mem-prealloc"
OPTS="$OPTS -rtc base=localtime,clock=host"
OPTS="$OPTS -drive if=virtio,format=raw,aio=threads,file=/media/null/scratch/vms/disk-images/windows-10.img"
OPTS="$OPTS -drive if=virtio,format=raw,aio=threads,file=/media/null/scratch/vms/disk-images/scratch.img"
OPTS="$OPTS -drive file=/dev/sdb,format=raw,if=virtio"
OPTS="$OPTS -device vfio-pci,host=00:1a.0" # USB bus 1
#OPTS="$OPTS -device vfio-pci,host=83:00.0" # Intel GBE 1
#OPTS="$OPTS -device vfio-pci,host=83:00.1" # Intel GBE 2
OPTS="$OPTS -device vfio-pci,host=05:00.0,multifunction=on,x-vga=on" # GTX 1070 GPU
OPTS="$OPTS -device vfio-pci,host=05:00.1" # GTX 1070 HDMI Audio
OPTS="$OPTS -net nic,model=virtio,macaddr=66:b3:11:1b:4e:98"
OPTS="$OPTS -net tap,ifname=tap0,script=no,downscript=no"
OPTS="$OPTS -monitor tcp:127.0.0.1:2562,server,nowait"
OPTS="$OPTS -display none"
OPTS="$OPTS -vga none"
function vmcpu-performance {
echo "setting VM CPU cores to performance mode..."
for (( i=0; i<32; i++ )); do echo performance > /sys/devices/system/cpu/cpu$i/cpufreq/scaling_governor; done
function memfree {
echo 0 > /sys/devices/system/node/node1/hugepages/hugepages-1048576kB/nr_hugepages
function run-vm {
echo "running \"$NAME\" virtual machine..."
sh -c "echo \$$ > /sys/fs/cgroup/cpuset/qemu-vcpu/tasks && /usr/bin/qemu-system-x86_64 $OPTS"
function kernel-setup {
sysctl kernel.sched_rt_runtime_us=980000
sysctl kernel.sched_latency_ns=1000000
sysctl kernel.sched_min_granularity_ns=500000
sysctl kernel.sched_wakeup_granularity_ns=500000
function shield-create {
echo "creating system cpuset..."
mkdir /sys/fs/cgroup/cpuset/system
echo 0 > /sys/fs/cgroup/cpuset/system/cpuset.mems
echo 0-6,16-22 > /sys/fs/cgroup/cpuset/system/cpuset.cpus
cat /sys/fs/cgroup/cpuset/tasks | xargs -n1 -i echo {} > /sys/fs/cgroup/cpuset/system/tasks
echo > /sys/fs/cgroup/cpuset/tasks
echo "creating qemu-virt cpuset..."
mkdir /sys/fs/cgroup/cpuset/qemu-virt
echo 0-1 > /sys/fs/cgroup/cpuset/qemu-virt/cpuset.mems
echo 7,23 > /sys/fs/cgroup/cpuset/qemu-virt/cpuset.cpus
echo "creating qemu-vcpu cpuset..."
mkdir /sys/fs/cgroup/cpuset/qemu-vcpu
echo 1 > /sys/fs/cgroup/cpuset/qemu-vcpu/cpuset.mems
echo 8-15,24-31 > /sys/fs/cgroup/cpuset/qemu-vcpu/cpuset.cpus
echo 1 > /sys/fs/cgroup/cpuset/system/cpuset.memory_migrate
echo 1 > /sys/fs/cgroup/cpuset/qemu-virt/cpuset.memory_migrate
#echo 1 > /sys/fs/cgroup/cpuset/qemu-vcpu/cpuset.mem_exclusive
echo 1 > /sys/fs/cgroup/cpuset/qemu-vcpu/cpuset.memory_migrate
function shield-destroy {
echo "removing system cpuset and returning threads to root cpuset..."
cat /sys/fs/cgroup/cpuset/system/tasks | xargs -n1 -i echo {} > /sys/fs/cgroup/cpuset/tasks
rmdir /sys/fs/cgroup/cpuset/system
echo "removing qemu-virt cpuset and returning threads to root cpuset..."
cat /sys/fs/cgroup/cpuset/qemu-virt/tasks | xargs -n1 -i echo {} > /sys/fs/cgroup/cpuset/tasks
rmdir /sys/fs/cgroup/cpuset/qemu-virt
echo "removing qemu-vcpu cpuset and returning threads to root cpuset..."
cat /sys/fs/cgroup/cpuset/qemu-vcpu/tasks | xargs -n1 -i echo {} > /sys/fs/cgroup/cpuset/tasks
rmdir /sys/fs/cgroup/cpuset/qemu-vcpu
function shield-threads {
sleep 20 &&
echo "shielding vm cores from host processes..."
echo $(pstree -pa $(pidof qemu-system-x86_64) | grep $NAME | awk -F',' '{print $2}' | awk '{print $1}') > /sys/fs/cgroup/cpuset/qemu-virt/tasks ;
HOST_THREAD=0
for PID in $(pstree -pa $(pstree -pa $(pidof qemu-system-x86_64) | grep $NAME | awk -F',' '{print $2}' | awk '{print $1}') | grep CPU | pstree -pa $(pstree -pa $(pidof qemu-system-x86_64) | grep $NAME | cut -d',' -f2 | cut -d' ' -f1) | grep CPU | sort | awk -F',' '{print $2}')
do let HOST_THREAD+=1
echo $PID > /sys/fs/cgroup/cpuset/qemu-vcpu/tasks
echo "taskset -pc $(echo $HOST_CPU_THREADS | cut -d',' -f$HOST_THREAD) $PID" | bash
done
function set-vm-realtime {
sleep 40 &&
echo "making virtual machine threads realtime..."
VPS=$(pstree -pa $(pidof qemu-system-x86_64) | grep $NAME | cut -d',' -f2 | cut -d' ' -f1)
pstree -pa $VPS | cut -d',' -f2 | cut -d' ' -f1 | xargs -L1 echo "chrt -f -p 99" | bash
vmcpu-performance
kernel-setup
init-pci
set-vm-realtime &
shield-create
shield-threads &
run-vm
shield-destroy
memfree
exit 0
