I only know VFIO and GPU passthrough exist because of level1 videos, so I figured this was probably the best place to come when I’ve hit a brick wall.
In short, the problem is hard lockups. Seemingly random. My host (Ubuntu 18.04 - 5.7 liquorix kernel) has never locked up like that on it’s own. It only happens when the guest VM is running. It can happen right away, or it can happen at any time up to hours of running/gaming. The problem I have really, is I don’t even know how to troubleshoot this. Any help with that is appreciated.
My hardware setup is an ASUS Crosshair Hero VIII WIFI, 3800x, 64gb pc3600 trident z neo, 1060 6gb host GPU, rx570 guest gpu, PCI-x USB card also passed through (USB audio and bluetooth connected to this card).
VM configuration is 8 cores, 16GB RAM, RX570 passthrough, USB card passthrough, raw image for C drive, 500gb SSD partition (by uuid) for game drive, network in macvtap bridge mode. Here’s the xml file.
WARNING: THIS IS AN AUTO-GENERATED FILE. CHANGES TO IT ARE LIKELY TO BE
OVERWRITTEN AND LOST. Changes to this xml configuration should be made using:
virsh edit win10
or other application using the libvirt API.
<domain type='kvm'>
<name>win10</name>
<uuid>253bfb95-2be8-407e-be75-c821d0a3efd5</uuid>
<memory unit='KiB'>16777216</memory>
<currentMemory unit='KiB'>16777216</currentMemory>
<vcpu placement='static'>8</vcpu>
<os>
<type arch='x86_64' machine='pc-i440fx-bionic'>hvm</type>
<loader readonly='yes' type='pflash'>/usr/share/OVMF/OVMF_CODE.fd</loader>
<nvram>/var/lib/libvirt/qemu/nvram/win10_VARS.fd</nvram>
</os>
<features>
<acpi/>
<apic/>
<hyperv>
<relaxed state='on'/>
<vapic state='on'/>
<spinlocks state='on' retries='8191'/>
</hyperv>
<vmport state='off'/>
</features>
<cpu mode='custom' match='exact' check='partial'>
<model fallback='allow'>EPYC</model>
<topology sockets='1' cores='4' threads='2'/>
</cpu>
<clock offset='localtime'>
<timer name='rtc' tickpolicy='catchup'/>
<timer name='pit' tickpolicy='delay'/>
<timer name='hpet' present='no'/>
<timer name='hypervclock' present='yes'/>
</clock>
<on_poweroff>destroy</on_poweroff>
<on_reboot>restart</on_reboot>
<on_crash>destroy</on_crash>
<pm>
<suspend-to-mem enabled='no'/>
<suspend-to-disk enabled='no'/>
</pm>
<devices>
<emulator>/usr/bin/kvm-spice</emulator>
<disk type='file' device='disk'>
<driver name='qemu' type='raw'/>
<source file='/mnt/NVME/vbox/win10.raw'/>
<target dev='vda' bus='virtio'/>
<boot order='2'/>
<address type='pci' domain='0x0000' bus='0x00' slot='0x09' function='0x0'/>
</disk>
<disk type='block' device='disk'>
<driver name='qemu' type='raw' cache='none' io='native'/>
<source dev='/dev/disk/by-partuuid/89ee49c8-01'/>
<target dev='vdb' bus='virtio'/>
<address type='pci' domain='0x0000' bus='0x00' slot='0x03' function='0x0'/>
</disk>
<disk type='file' device='cdrom'>
<target dev='sda' bus='sata'/>
<readonly/>
<address type='drive' controller='0' bus='0' target='0' unit='0'/>
</disk>
<controller type='pci' index='0' model='pci-root'/>
<controller type='ide' index='0'>
<address type='pci' domain='0x0000' bus='0x00' slot='0x01' function='0x1'/>
</controller>
<controller type='sata' index='0'>
<address type='pci' domain='0x0000' bus='0x00' slot='0x06' function='0x0'/>
</controller>
<controller type='virtio-serial' index='0'>
<address type='pci' domain='0x0000' bus='0x00' slot='0x07' function='0x0'/>
</controller>
<controller type='usb' index='0' model='ich9-ehci1'>
<address type='pci' domain='0x0000' bus='0x00' slot='0x05' function='0x7'/>
</controller>
<controller type='usb' index='0' model='ich9-uhci1'>
<master startport='0'/>
<address type='pci' domain='0x0000' bus='0x00' slot='0x05' function='0x0' multifunction='on'/>
</controller>
<controller type='usb' index='0' model='ich9-uhci2'>
<master startport='2'/>
<address type='pci' domain='0x0000' bus='0x00' slot='0x05' function='0x1'/>
</controller>
<controller type='usb' index='0' model='ich9-uhci3'>
<master startport='4'/>
<address type='pci' domain='0x0000' bus='0x00' slot='0x05' function='0x2'/>
</controller>
<interface type='direct'>
<mac address='52:54:00:f1:fb:53'/>
<source dev='enp5s0' mode='bridge'/>
<model type='rtl8139'/>
<address type='pci' domain='0x0000' bus='0x00' slot='0x0c' function='0x0'/>
</interface>
<serial type='pty'>
<target type='isa-serial' port='0'>
<model name='isa-serial'/>
</target>
</serial>
<console type='pty'>
<target type='serial' port='0'/>
</console>
<channel type='spicevmc'>
<target type='virtio' name='com.redhat.spice.0'/>
<address type='virtio-serial' controller='0' bus='0' port='1'/>
</channel>
<input type='tablet' bus='usb'>
<address type='usb' bus='0' port='1'/>
</input>
<input type='mouse' bus='ps2'/>
<input type='keyboard' bus='ps2'/>
<sound model='ich6'>
<address type='pci' domain='0x0000' bus='0x00' slot='0x04' function='0x0'/>
</sound>
<hostdev mode='subsystem' type='pci' managed='yes'>
<source>
<address domain='0x0000' bus='0x0c' slot='0x00' function='0x0'/>
</source>
<address type='pci' domain='0x0000' bus='0x00' slot='0x02' function='0x0'/>
</hostdev>
<source>
<address domain='0x0000' bus='0x0c' slot='0x00' function='0x1'/>
</source>
<address type='pci' domain='0x0000' bus='0x00' slot='0x0a' function='0x0'/>
</hostdev>
<source>
<address domain='0x0000' bus='0x04' slot='0x00' function='0x0'/>
</source>
<address type='pci' domain='0x0000' bus='0x00' slot='0x0b' function='0x0'/>
</hostdev>
<redirdev bus='usb' type='spicevmc'>
<address type='usb' bus='0' port='2'/>
</redirdev>
<address type='usb' bus='0' port='3'/>
</redirdev>
<memballoon model='virtio'>
<address type='pci' domain='0x0000' bus='0x00' slot='0x08' function='0x0'/>
</memballoon>
</devices>
</domain>
IOMMU list
IOMMU Group 0 00:01.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Device [1022:1482]
IOMMU Group 10 00:07.1 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:1484]
IOMMU Group 11 00:08.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Device [1022:1482]
IOMMU Group 12 00:08.1 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:1484]
IOMMU Group 13 00:08.2 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:1484]
IOMMU Group 14 00:08.3 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:1484]
IOMMU Group 15 00:14.0 SMBus [0c05]: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller [1022:790b] (rev 61)
IOMMU Group 15 00:14.3 ISA bridge [0601]: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge [1022:790e] (rev 51)
IOMMU Group 16 00:18.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Device [1022:1440]
IOMMU Group 16 00:18.1 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Device [1022:1441]
IOMMU Group 16 00:18.2 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Device [1022:1442]
IOMMU Group 16 00:18.3 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Device [1022:1443]
IOMMU Group 16 00:18.4 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Device [1022:1444]
IOMMU Group 16 00:18.5 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Device [1022:1445]
IOMMU Group 16 00:18.6 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Device [1022:1446]
IOMMU Group 16 00:18.7 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Device [1022:1447]
IOMMU Group 17 01:00.0 Non-Volatile memory controller [0108]: Micron/Crucial Technology Device [c0a9:2263] (rev 03)
IOMMU Group 18 02:00.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:57ad]
IOMMU Group 19 03:02.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:57a3]
IOMMU Group 1 00:01.1 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:1483]
IOMMU Group 20 03:03.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:57a3]
IOMMU Group 21 03:05.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:57a3]
IOMMU Group 22 03:06.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:57a3]
IOMMU Group 23 03:08.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:57a4]
IOMMU Group 23 08:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Device [1022:1485]
IOMMU Group 23 08:00.1 USB controller [0c03]: Advanced Micro Devices, Inc. [AMD] Device [1022:149c]
IOMMU Group 23 08:00.3 USB controller [0c03]: Advanced Micro Devices, Inc. [AMD] Device [1022:149c]
IOMMU Group 24 03:09.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:57a4]
IOMMU Group 24 09:00.0 SATA controller [0106]: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] [1022:7901] (rev 51)
IOMMU Group 25 03:0a.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:57a4]
IOMMU Group 25 0a:00.0 SATA controller [0106]: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] [1022:7901] (rev 51)
IOMMU Group 26 04:00.0 USB controller [0c03]: Renesas Technology Corp. uPD720202 USB 3.0 Host Controller [1912:0015] (rev 02)
IOMMU Group 27 05:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. Device [10ec:8125]
IOMMU Group 28 06:00.0 Ethernet controller [0200]: Intel Corporation I211 Gigabit Network Connection [8086:1539] (rev 03)
IOMMU Group 29 07:00.0 Network controller [0280]: Intel Corporation Device [8086:2723] (rev 1a)
IOMMU Group 2 00:01.2 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:1483]
IOMMU Group 30 0b:00.0 VGA compatible controller [0300]: NVIDIA Corporation GP106 [GeForce GTX 1060 6GB] [10de:1c03] (rev a1)
IOMMU Group 30 0b:00.1 Audio device [0403]: NVIDIA Corporation GP106 High Definition Audio Controller [10de:10f1] (rev a1)
IOMMU Group 31 0c:00.0 VGA compatible controller [0300]: Advanced Micro Devices, Inc. [AMD/ATI] Ellesmere [Radeon RX 470/480/570/570X/580/580X] [1002:67df] (rev ef)
IOMMU Group 31 0c:00.1 Audio device [0403]: Advanced Micro Devices, Inc. [AMD/ATI] Ellesmere [Radeon RX 580] [1002:aaf0]
IOMMU Group 32 0d:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Device [1022:148a]
IOMMU Group 33 0e:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Device [1022:1485]
IOMMU Group 34 0e:00.1 Encryption controller [1080]: Advanced Micro Devices, Inc. [AMD] Device [1022:1486]
IOMMU Group 35 0e:00.3 USB controller [0c03]: Advanced Micro Devices, Inc. [AMD] Device [1022:149c]
IOMMU Group 36 0e:00.4 Audio device [0403]: Advanced Micro Devices, Inc. [AMD] Device [1022:1487]
IOMMU Group 37 0f:00.0 SATA controller [0106]: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] [1022:7901] (rev 51)
IOMMU Group 38 10:00.0 SATA controller [0106]: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] [1022:7901] (rev 51)
IOMMU Group 3 00:02.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Device [1022:1482]
IOMMU Group 4 00:03.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Device [1022:1482]
IOMMU Group 5 00:03.1 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:1483]
IOMMU Group 6 00:03.2 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:1483]
IOMMU Group 7 00:04.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Device [1022:1482]
IOMMU Group 8 00:05.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Device [1022:1482]
IOMMU Group 9 00:07.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Device [1022:1482]
/etc/modprobe.d/vfio.conf
options vfio-pci ids=1002:67df,1002:aaf0,10ec:8125,1912:0015
/etc/modules
vfio vfio_iommu_type1 vfio_pci ids=1002:67df,1002:aaf0,10ec:8125,1912:0015
/etc/initramfs/tools/modules
/etc/modprobe.d/kvm.conf
/var/log/libvirt/qemu/win10.log
2020-07-13 21:45:18.556+0000: starting up libvirt version: 4.0.0, package: 1ubuntu8.17 (Marc Deslauriers <[email protected]> Wed, 06 May 2020 14:18:23 -0400), qemu version: 2.11.1(Debian 1:2.11+dfsg-1ubuntu7.28), hostname: Optiplex
LC_ALL=C PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/snap/bin QEMU_AUDIO_DRV=none /usr/bin/kvm-spice -name guest=win10,debug-threads=on -S -object secret,id=masterKey0,format=raw,file=/var/lib/libvirt/qemu/domain-1-win10/master-key.aes -machine pc-i440fx-bionic,accel=kvm,usb=off,vmport=off,dump-guest-core=off -cpu EPYC,hv_time,hv_relaxed,hv_vapic,hv_spinlocks=0x1fff -drive file=/usr/share/OVMF/OVMF_CODE.fd,if=pflash,format=raw,unit=0,readonly=on -drive file=/var/lib/libvirt/qemu/nvram/win10_VARS.fd,if=pflash,format=raw,unit=1 -m 16384 -realtime mlock=off -smp 8,sockets=1,cores=4,threads=2 -uuid 253bfb95-2be8-407e-be75-c821d0a3efd5 -display none -no-user-config -nodefaults -chardev socket,id=charmonitor,path=/var/lib/libvirt/qemu/domain-1-win10/monitor.sock,server,nowait -mon chardev=charmonitor,id=monitor,mode=control -rtc base=localtime,driftfix=slew -global kvm-pit.lost_tick_policy=delay -no-hpet -no-shutdown -global PIIX4_PM.disable_s3=1 -global PIIX4_PM.disable_s4=1 -boot strict=on -device ich9-usb-ehci1,id=usb,bus=pci.0,addr=0x5.0x7 -device ich9-usb-uhci1,masterbus=usb.0,firstport=0,bus=pci.0,multifunction=on,addr=0x5 -device ich9-usb-uhci2,masterbus=usb.0,firstport=2,bus=pci.0,addr=0x5.0x1 -device ich9-usb-uhci3,masterbus=usb.0,firstport=4,bus=pci.0,addr=0x5.0x2 -device ahci,id=sata0,bus=pci.0,addr=0x6 -device virtio-serial-pci,id=virtio-serial0,bus=pci.0,addr=0x7 -drive file=/mnt/NVME/vbox/win10.raw,format=raw,if=none,id=drive-virtio-disk0 -device virtio-blk-pci,scsi=off,bus=pci.0,addr=0x9,drive=drive-virtio-disk0,id=virtio-disk0,bootindex=2 -drive file=/dev/disk/by-partuuid/89ee49c8-01,format=raw,if=none,id=drive-virtio-disk1,cache=none,aio=native -device virtio-blk-pci,scsi=off,bus=pci.0,addr=0x3,drive=drive-virtio-disk1,id=virtio-disk1 -drive if=none,id=drive-sata0-0-0,media=cdrom,readonly=on -device ide-cd,bus=sata0.0,drive=drive-sata0-0-0,id=sata0-0-0 -chardev pty,id=charserial0 -device isa-serial,chardev=charserial0,id=serial0 -chardev spicevmc,id=charchannel0,name=vdagent -device virtserialport,bus=virtio-serial0.0,nr=1,chardev=charchannel0,id=channel0,name=com.redhat.spice.0 -device usb-tablet,id=input0,bus=usb.0,port=1 -device intel-hda,id=sound0,bus=pci.0,addr=0x4 -device hda-duplex,id=sound0-codec0,bus=sound0.0,cad=0 -chardev spicevmc,id=charredir0,name=usbredir -device usb-redir,chardev=charredir0,id=redir0,bus=usb.0,port=2 -chardev spicevmc,id=charredir1,name=usbredir -device usb-redir,chardev=charredir1,id=redir1,bus=usb.0,port=3 -device usb-host,hostbus=7,hostaddr=2,id=hostdev0,bus=usb.0,port=4 -device vfio-pci,host=0c:00.0,id=hostdev1,bus=pci.0,addr=0x2 -device vfio-pci,host=0c:00.1,id=hostdev2,bus=pci.0,addr=0xa -device vfio-pci,host=04:00.0,id=hostdev3,bus=pci.0,addr=0xb -device virtio-balloon-pci,id=balloon0,bus=pci.0,addr=0x8 -msg timestamp=on
2020-07-13T21:45:18.635521Z qemu-system-x86_64: -chardev pty,id=charserial0: char device redirected to /dev/pts/1 (label charserial0)
2020-07-13T21:45:18.653481Z qemu-system-x86_64: AMD CPU doesn't support hyperthreading. Please configure -smp options properly.
2020-07-13T21:45:52.516924Z qemu-system-x86_64: warning: guest updated active QH
2020-07-13T21:46:58.626706Z qemu-system-x86_64: warning: guest updated active QH
2020-07-13T21:49:14.077545Z qemu-system-x86_64: warning: guest updated active QH
2020-07-13T21:49:20.203320Z qemu-system-x86_64: terminating on signal 15 from pid 1564 (/usr/sbin/libvirtd)
2020-07-13 21:49:22.606+0000: shutting down, reason=shutdown
2020-07-13 21:53:52.833+0000: starting up libvirt version: 4.0.0, package: 1ubuntu8.17 (Marc Deslauriers <[email protected]> Wed, 06 May 2020 14:18:23 -0400), qemu version: 2.11.1(Debian 1:2.11+dfsg-1ubuntu7.28), hostname: Optiplex
LC_ALL=C PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/snap/bin QEMU_AUDIO_DRV=none /usr/bin/kvm-spice -name guest=win10,debug-threads=on -S -object secret,id=masterKey0,format=raw,file=/var/lib/libvirt/qemu/domain-1-win10/master-key.aes -machine pc-i440fx-bionic,accel=kvm,usb=off,vmport=off,dump-guest-core=off -cpu EPYC,hv_time,hv_relaxed,hv_vapic,hv_spinlocks=0x1fff -drive file=/usr/share/OVMF/OVMF_CODE.fd,if=pflash,format=raw,unit=0,readonly=on -drive file=/var/lib/libvirt/qemu/nvram/win10_VARS.fd,if=pflash,format=raw,unit=1 -m 16384 -realtime mlock=off -smp 8,sockets=1,cores=4,threads=2 -uuid 253bfb95-2be8-407e-be75-c821d0a3efd5 -display none -no-user-config -nodefaults -chardev socket,id=charmonitor,path=/var/lib/libvirt/qemu/domain-1-win10/monitor.sock,server,nowait -mon chardev=charmonitor,id=monitor,mode=control -rtc base=localtime,driftfix=slew -global kvm-pit.lost_tick_policy=delay -no-hpet -no-shutdown -global PIIX4_PM.disable_s3=1 -global PIIX4_PM.disable_s4=1 -boot strict=on -device ich9-usb-ehci1,id=usb,bus=pci.0,addr=0x5.0x7 -device ich9-usb-uhci1,masterbus=usb.0,firstport=0,bus=pci.0,multifunction=on,addr=0x5 -device ich9-usb-uhci2,masterbus=usb.0,firstport=2,bus=pci.0,addr=0x5.0x1 -device ich9-usb-uhci3,masterbus=usb.0,firstport=4,bus=pci.0,addr=0x5.0x2 -device ahci,id=sata0,bus=pci.0,addr=0x6 -device virtio-serial-pci,id=virtio-serial0,bus=pci.0,addr=0x7 -drive file=/mnt/NVME/vbox/win10.raw,format=raw,if=none,id=drive-virtio-disk0 -device virtio-blk-pci,scsi=off,bus=pci.0,addr=0x9,drive=drive-virtio-disk0,id=virtio-disk0,bootindex=2 -drive file=/dev/disk/by-partuuid/89ee49c8-01,format=raw,if=none,id=drive-virtio-disk1,cache=none,aio=native -device virtio-blk-pci,scsi=off,bus=pci.0,addr=0x3,drive=drive-virtio-disk1,id=virtio-disk1 -drive if=none,id=drive-sata0-0-0,media=cdrom,readonly=on -device ide-cd,bus=sata0.0,drive=drive-sata0-0-0,id=sata0-0-0 -chardev pty,id=charserial0 -device isa-serial,chardev=charserial0,id=serial0 -chardev spicevmc,id=charchannel0,name=vdagent -device virtserialport,bus=virtio-serial0.0,nr=1,chardev=charchannel0,id=channel0,name=com.redhat.spice.0 -device usb-tablet,id=input0,bus=usb.0,port=1 -device intel-hda,id=sound0,bus=pci.0,addr=0x4 -device hda-duplex,id=sound0-codec0,bus=sound0.0,cad=0 -chardev spicevmc,id=charredir0,name=usbredir -device usb-redir,chardev=charredir0,id=redir0,bus=usb.0,port=2 -chardev spicevmc,id=charredir1,name=usbredir -device usb-redir,chardev=charredir1,id=redir1,bus=usb.0,port=3 -device vfio-pci,host=0c:00.0,id=hostdev0,bus=pci.0,addr=0x2 -device vfio-pci,host=0c:00.1,id=hostdev1,bus=pci.0,addr=0xa -device vfio-pci,host=04:00.0,id=hostdev2,bus=pci.0,addr=0xb -device virtio-balloon-pci,id=balloon0,bus=pci.0,addr=0x8 -msg timestamp=on
2020-07-13T21:53:52.907761Z qemu-system-x86_64: -chardev pty,id=charserial0: char device redirected to /dev/pts/0 (label charserial0)
2020-07-13T21:53:52.925811Z qemu-system-x86_64: AMD CPU doesn't support hyperthreading. Please configure -smp options properly.
2020-07-13 22:15:34.142+0000: starting up libvirt version: 4.0.0, package: 1ubuntu8.17 (Marc Deslauriers <[email protected]> Wed, 06 May 2020 14:18:23 -0400), qemu version: 2.11.1(Debian 1:2.11+dfsg-1ubuntu7.28), hostname: Optiplex
LC_ALL=C PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/snap/bin QEMU_AUDIO_DRV=none /usr/bin/kvm-spice -name guest=win10,debug-threads=on -S -object secret,id=masterKey0,format=raw,file=/var/lib/libvirt/qemu/domain-1-win10/master-key.aes -machine pc-i440fx-bionic,accel=kvm,usb=off,vmport=off,dump-guest-core=off -cpu EPYC,hv_time,hv_relaxed,hv_vapic,hv_spinlocks=0x1fff -drive file=/usr/share/OVMF/OVMF_CODE.fd,if=pflash,format=raw,unit=0,readonly=on -drive file=/var/lib/libvirt/qemu/nvram/win10_VARS.fd,if=pflash,format=raw,unit=1 -m 16384 -realtime mlock=off -smp 8,sockets=1,cores=4,threads=2 -uuid 253bfb95-2be8-407e-be75-c821d0a3efd5 -display none -no-user-config -nodefaults -chardev socket,id=charmonitor,path=/var/lib/libvirt/qemu/domain-1-win10/monitor.sock,server,nowait -mon chardev=charmonitor,id=monitor,mode=control -rtc base=localtime,driftfix=slew -global kvm-pit.lost_tick_policy=delay -no-hpet -no-shutdown -global PIIX4_PM.disable_s3=1 -global PIIX4_PM.disable_s4=1 -boot strict=on -device ich9-usb-ehci1,id=usb,bus=pci.0,addr=0x5.0x7 -device ich9-usb-uhci1,masterbus=usb.0,firstport=0,bus=pci.0,multifunction=on,addr=0x5 -device ich9-usb-uhci2,masterbus=usb.0,firstport=2,bus=pci.0,addr=0x5.0x1 -device ich9-usb-uhci3,masterbus=usb.0,firstport=4,bus=pci.0,addr=0x5.0x2 -device ahci,id=sata0,bus=pci.0,addr=0x6 -device virtio-serial-pci,id=virtio-serial0,bus=pci.0,addr=0x7 -drive file=/mnt/NVME/vbox/win10.raw,format=raw,if=none,id=drive-virtio-disk0 -device virtio-blk-pci,scsi=off,bus=pci.0,addr=0x9,drive=drive-virtio-disk0,id=virtio-disk0,bootindex=2 -drive file=/dev/disk/by-partuuid/89ee49c8-01,format=raw,if=none,id=drive-virtio-disk1,cache=none,aio=native -device virtio-blk-pci,scsi=off,bus=pci.0,addr=0x3,drive=drive-virtio-disk1,id=virtio-disk1 -drive if=none,id=drive-sata0-0-0,media=cdrom,readonly=on -device ide-cd,bus=sata0.0,drive=drive-sata0-0-0,id=sata0-0-0 -netdev tap,fd=21,id=hostnet0 -device rtl8139,netdev=hostnet0,id=net0,mac=52:54:00:f1:fb:53,bus=pci.0,addr=0xc -chardev pty,id=charserial0 -device isa-serial,chardev=charserial0,id=serial0 -chardev spicevmc,id=charchannel0,name=vdagent -device virtserialport,bus=virtio-serial0.0,nr=1,chardev=charchannel0,id=channel0,name=com.redhat.spice.0 -device usb-tablet,id=input0,bus=usb.0,port=1 -device intel-hda,id=sound0,bus=pci.0,addr=0x4 -device hda-duplex,id=sound0-codec0,bus=sound0.0,cad=0 -chardev spicevmc,id=charredir0,name=usbredir -device usb-redir,chardev=charredir0,id=redir0,bus=usb.0,port=2 -chardev spicevmc,id=charredir1,name=usbredir -device usb-redir,chardev=charredir1,id=redir1,bus=usb.0,port=3 -device vfio-pci,host=0c:00.0,id=hostdev0,bus=pci.0,addr=0x2 -device vfio-pci,host=0c:00.1,id=hostdev1,bus=pci.0,addr=0xa -device vfio-pci,host=04:00.0,id=hostdev2,bus=pci.0,addr=0xb -device virtio-balloon-pci,id=balloon0,bus=pci.0,addr=0x8 -msg timestamp=on
2020-07-13T22:15:34.224139Z qemu-system-x86_64: -chardev pty,id=charserial0: char device redirected to /dev/pts/0 (label charserial0)
2020-07-13T22:15:34.242223Z qemu-system-x86_64: AMD CPU doesn't support hyperthreading. Please configure -smp options properly.
Let me know if you need anything else.
