output of lspci -nnvk
00:00.0 Host bridge [0600]: Intel Corporation 4th Gen Core Processor DRAM Controller [8086:0c00] (rev 06)
Subsystem: Micro-Star International Co., Ltd. [MSI] 4th Gen Core Processor DRAM Controller [1462:7917]
Flags: bus master, fast devsel, latency 0
Capabilities: <access denied>
Kernel driver in use: hsw_uncore
lspci: Unable to load libkmod resources: error -12
00:01.0 PCI bridge [0604]: Intel Corporation Xeon E3-1200 v3/4th Gen Core Processor PCI Express x16 Controller [8086:0c01] (rev 06) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 25
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: 0000e000-0000efff [size=4K]
Memory behind bridge: f6000000-f70fffff [size=17M]
Prefetchable memory behind bridge: 00000000c0000000-00000000d1ffffff [size=288M]
Kernel driver in use: pcieport
00:01.1 PCI bridge [0604]: Intel Corporation Xeon E3-1200 v3/4th Gen Core Processor PCI Express x8 Controller [8086:0c05] (rev 06) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 26
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
I/O behind bridge: 0000d000-0000dfff [size=4K]
Memory behind bridge: f7300000-f73fffff [size=1M]
Prefetchable memory behind bridge: 00000000e0000000-00000000f01fffff [size=258M]
00:01.2 PCI bridge [0604]: Intel Corporation Xeon E3-1200 v3/4th Gen Core Processor PCI Express x4 Controller [8086:0c09] (rev 06) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 27
Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
I/O behind bridge: [disabled]
Memory behind bridge: f7200000-f72fffff [size=1M]
Prefetchable memory behind bridge: [disabled]
00:14.0 USB controller [0c03]: Intel Corporation 9 Series Chipset Family USB xHCI Controller [8086:8cb1] (prog-if 30 [XHCI])
Subsystem: Micro-Star International Co., Ltd. [MSI] 9 Series Chipset Family USB xHCI Controller [1462:7917]
Flags: bus master, medium devsel, latency 0, IRQ 39
Memory at f7400000 (64-bit, non-prefetchable) [size=64K]
Kernel driver in use: xhci_hcd
00:16.0 Communication controller [0780]: Intel Corporation 9 Series Chipset Family ME Interface #1 [8086:8cba]
Subsystem: Micro-Star International Co., Ltd. [MSI] 9 Series Chipset Family ME Interface [1462:7917]
Flags: bus master, fast devsel, latency 0, IRQ 40
Memory at f7419000 (64-bit, non-prefetchable) [size=16]
Kernel driver in use: mei_me
00:1a.0 USB controller [0c03]: Intel Corporation 9 Series Chipset Family USB EHCI Controller #2 [8086:8cad] (prog-if 20 [EHCI])
Subsystem: Micro-Star International Co., Ltd. [MSI] 9 Series Chipset Family USB EHCI Controller [1462:7917]
Flags: bus master, medium devsel, latency 0, IRQ 16
Memory at f7417000 (32-bit, non-prefetchable) [size=1K]
Kernel driver in use: ehci-pci
00:1b.0 Audio device [0403]: Intel Corporation 9 Series Chipset Family HD Audio Controller [8086:8ca0]
Subsystem: Micro-Star International Co., Ltd. [MSI] 9 Series Chipset Family HD Audio Controller [1462:d917]
Flags: bus master, fast devsel, latency 0, IRQ 41
Memory at f7410000 (64-bit, non-prefetchable) [size=16K]
Kernel driver in use: snd_hda_intel
00:1c.0 PCI bridge [0604]: Intel Corporation 9 Series Chipset Family PCI Express Root Port 1 [8086:8c90] (rev d0) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 28
Bus: primary=00, secondary=04, subordinate=04, sec-latency=0
Memory behind bridge: [disabled]
00:1c.3 PCI bridge [0604]: Intel Corporation 9 Series Chipset Family PCI Express Root Port 4 [8086:8c96] (rev d0) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 29
Bus: primary=00, secondary=05, subordinate=05, sec-latency=0
I/O behind bridge: 0000c000-0000cfff [size=4K]
Memory behind bridge: f7100000-f71fffff [size=1M]
00:1d.0 USB controller [0c03]: Intel Corporation 9 Series Chipset Family USB EHCI Controller #1 [8086:8ca6] (prog-if 20 [EHCI])
Flags: bus master, medium devsel, latency 0, IRQ 23
Memory at f7416000 (32-bit, non-prefetchable) [size=1K]
00:1f.0 ISA bridge [0601]: Intel Corporation Z97 Chipset LPC Controller [8086:8cc4]
Subsystem: Micro-Star International Co., Ltd. [MSI] Z97 Chipset LPC Controller [1462:7917]
Kernel driver in use: lpc_ich
00:1f.2 SATA controller [0106]: Intel Corporation 9 Series Chipset Family SATA Controller [AHCI Mode] [8086:8c82] (prog-if 01 [AHCI 1.0])
Subsystem: Micro-Star International Co., Ltd. [MSI] 9 Series Chipset Family SATA Controller [AHCI Mode] [1462:7917]
Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 31
I/O ports at f070 [size=8]
I/O ports at f060 [size=4]
I/O ports at f050 [size=8]
I/O ports at f040 [size=4]
I/O ports at f020 [size=32]
Memory at f7415000 (32-bit, non-prefetchable) [size=2K]
Kernel driver in use: ahci
00:1f.3 SMBus [0c05]: Intel Corporation 9 Series Chipset Family SMBus Controller [8086:8ca2]
Subsystem: Micro-Star International Co., Ltd. [MSI] 9 Series Chipset Family SMBus Controller [1462:7917]
Flags: medium devsel, IRQ 18
Memory at f7414000 (64-bit, non-prefetchable) [size=256]
I/O ports at f000 [size=32]
Kernel driver in use: i801_smbus
01:00.0 VGA compatible controller [0300]: NVIDIA Corporation GP102 [GeForce GTX 1080 Ti] [10de:1b06] (rev a1) (prog-if 00 [VGA controller])
Subsystem: Micro-Star International Co., Ltd. [MSI] GP102 [GeForce GTX 1080 Ti] [1462:3602]
Flags: bus master, fast devsel, latency 0, IRQ 47
Memory at f6000000 (32-bit, non-prefetchable) [size=16M]
Memory at c0000000 (64-bit, prefetchable) [size=256M]
Memory at d0000000 (64-bit, prefetchable) [size=32M]
I/O ports at e000 [size=128]
Expansion ROM at 000c0000 [virtual] [disabled] [size=128K]
Kernel driver in use: nvidia
01:00.1 Audio device [0403]: NVIDIA Corporation GP102 HDMI Audio Controller [10de:10ef] (rev a1)
Subsystem: Micro-Star International Co., Ltd. [MSI] GP102 HDMI Audio Controller [1462:3602]
Flags: bus master, fast devsel, latency 0, IRQ 17
Memory at f7080000 (32-bit, non-prefetchable) [size=16K]
02:00.0 VGA compatible controller [0300]: Advanced Micro Devices, Inc. [AMD/ATI] Ellesmere [Radeon RX 470/480/570/570X/580/580X/590] [1002:67df] (rev ef) (prog-if 00 [VGA controller])
Subsystem: Micro-Star International Co., Ltd. [MSI] Ellesmere [Radeon RX 470/480/570/570X/580/580X/590] [1462:341b]
Flags: fast devsel, IRQ 10
Memory at e0000000 (64-bit, prefetchable) [disabled] [size=256M]
Memory at f0000000 (64-bit, prefetchable) [disabled] [size=2M]
I/O ports at d000 [disabled] [size=256]
Memory at f7300000 (32-bit, non-prefetchable) [disabled] [size=256K]
Expansion ROM at f7340000 [disabled] [size=128K]
Kernel driver in use: vfio-pci
02:00.1 Audio device [0403]: Advanced Micro Devices, Inc. [AMD/ATI] Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590] [1002:aaf0]
Subsystem: Micro-Star International Co., Ltd. [MSI] Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590] [1462:aaf0]
Flags: bus master, fast devsel, latency 0, IRQ 5
Memory at f7360000 (64-bit, non-prefetchable) [size=16K]
03:00.0 Non-Volatile memory controller [0108]: Samsung Electronics Co Ltd NVMe SSD Controller SM961/PM961 [144d:a804] (prog-if 02 [NVM Express])
Subsystem: Samsung Electronics Co Ltd NVMe SSD Controller SM961/PM961 [144d:a801]
Flags: bus master, fast devsel, latency 0, IRQ 18, NUMA node 0
Memory at f7200000 (64-bit, non-prefetchable) [size=16K]
Kernel driver in use: nvme
05:00.0 Ethernet controller [0200]: Qualcomm Atheros Killer E220x Gigabit Ethernet Controller [1969:e091] (rev 13)
Subsystem: Micro-Star International Co., Ltd. [MSI] Killer E220x Gigabit Ethernet Controller [1462:7917]
Flags: bus master, fast devsel, latency 0, IRQ 19
Memory at f7100000 (64-bit, non-prefetchable) [size=256K]
I/O ports at c000 [size=128]
Kernel driver in use: alx
this is the output of the script
IOMMU Group 0:
IOMMU Group 1:
IOMMU Group 10:
IOMMU Group 2:
IOMMU Group 3:
IOMMU Group 4:
IOMMU Group 5:
IOMMU Group 6:
IOMMU Group 7:
IOMMU Group 8:
IOMMU Group 9:
