I have a q6600 on a MSI p6N diamond with a zalman 9700led cpu fan. I want to overclock it. I was hoping to do about 3.2 or 3.4 ghz. Is that feasible? If yes what programs should I use and can I do it without doing stuff in the bios?
lol it's set at auto, so it varies from 1.2-low 1.3v
i dunno if i should just set it to low 1.3, but for now it's left on auto because i haven't seen it go anywhere near 1.4v and i want it to last as long as it can. so unless i'm doing something something cpu intensive, (games/video editing, etc etc) i don't mind the auto setting toning down the speed and voltage of the cpu for me.
oh and after about 9 hours of prime95 running (while i was sleeping) max temps rose to 55ºC, 53ºC, 52ºC and 49ºC. so i'll say i did a damn good job at not putting too much thermal grease and putting on the zerotherm nirvana, for a first timer that is.
YESS i finally grew the balls to screw my warranty fear and overclock that shit. Right now i am at 3ghz on myq6600 on an msi p6n diamond. core temps at 100% load are 52 52 47 48. Question these are my current settings, what do you guys think?
FSB Clock 1333
Memory Clock 700 (btw I have no iea about memory clocks why they are important and at which speeds i should run em, I read that some dude used that speed on the same mobo as me so i copied, should I increase, decrease leave at same?)
Multiplier x9
dram config 5 4 4 15, 1t
pcie freq 100
cpu volts: 0.0375v
mem volts 2.0v (how is this number important? if my memory specs say 2.1 v, how much does it matter that i ve set it at 2,)
