Hi everyone. I am currently thinking about using a SATA 12volt to DC power cable to run a Razer RGB controller that comes with a molex to DC adapter.
Basically I don’t want to add the molex cable to m psu and would like to use one of the SATA cables that are plugged anyway.
So checking the Razer device it seems it might drag up to 5 amps.
Is that something that a SATA connector can do? I kinda doubt that?
As far as i found out, molex can support up to 11 amps.
SATA only 1.5 A per rail. So for my needed 12V it’s waay to low. Am i right?
Seems like the Razer device is really hungry.
The Rgb hub from Bequiet that i planned/intended to use uses only sata to power the RGB plus an Argb header cable (which Mainboard does not have, thus the Razer Controller).
Hmmm
Found this, it’s German but you get what my worries are
schadenprisma https://www.schadenprisma.de › …PDF
Brandgefahr durch Molex-SATA-Adapter in PCs
The SATA-Power Connector contains 15 pins, off which 3x 3.3V, 3x 5V and 3x 12V
Each one of those pins has to be able to supply 1.5A, so 4.5A total per Voltage-Rail.
Thank you. Ik that’s not enough current on the SATA rail then to feed that Razer controller hmm.
Another question.
I have 7 fans in my case, all controlled by the little Bequiet case fan hub which gets a pwm from board but only supplies 3 pin connectors for 6 fans.
So i found out that this is not ideal. As pwm can be used to lower the rpm more than just pure voltage control.
So i planned to use the Mainboard fan headers instead to get pwm.
These are rated 36watt 3Amps.
Would you say it’s safe to splice via Y to 3 fans each 0.3 A?
I was wondering that the Asus sage wifi supplies 36W per header vs consumer boards that often only have 12W?
There are fan-hubs that locally use PWM to modulate the supply voltage they forward to the fans.
Depends on the fans. Their datasheet should have numbers regarding power draw.
Fan header implementations on mainboards are all over the place, consult the manual or specifications to make sure you don’t accidentally damage something.
I would buy an inexpensive pci-e splitter so you don’t have to cut up you cables https://www.aliexpress.us/item/3256805693286376.html I would not however endorse using this specific adapter for its original purpose
again using these for the original purpose is probably a fire starter but as long as you’re handy with a soldering iron cutting this up for a barrel jack should be fine, just keep in mind the polarity
Yes Iam.soldering all kind of things. I will think about it. Plus get my multimeter from the garage.
Point behind all that is that I already have a ton of cables in the case /psu /side panel.
Btw for my fan issue.
I just checked the other trx 50 boards manuals. Seems they have 2Amp fan headers. Plus ARGB.
Makes me feel special now. No ARGB header but 3A fan headers on the Asus yeyy
If you don’t hear back from me within 3 days - a fire took it all down
Tomorrow the Y fan splice cables will arrive. Maybe on the weekend i will test it then with the fans.
Curious to see if going with PWM is an improvement vs the Bequiet case pcb/fan controller that only uses 3 pin on each fan header.
Anyway - today the Razer Chroma Rgb controller arrived. Software controls my mouse and goliath padbanyway. So i added the fans too.
Alright. No fire yet. I use pwm to 3 fan splitter. Asus confirmed this is working.
Took down the Idle rpm a bit. Dead silent from seat position.
Under load i also experienced it’s not ramping up so high.
Iam happy how it worked out so far.
