When purchasing RAM for a AMD EYPC 75f3 and a supermicro h12ssl ct
Should there be any other consideration of specs other than
DDR4
Ecc
3200
I’ve been searching through eBay and I don’t know I just they all look the same I can’t really dig into the model numbers other than those parameters
I like the OWC kit I don’t know it’s blue all the others are green that’s kind of cool
So I want to go buy one of those kits of 256 gigs
The only difference I see is some of them are
2rx4. Some are 4rx4
So if I’m looking for just the best I can get what should I be considering in terms of those types of SKU numbers I know that they’re quadrank module versus dual rank
Other than that I don’t know which one’s better for this CPU motherboard combination
