I have a Corsair RM850x 2021 PSU powering a Ryzen 5800x and a GTX 960 with an Asus B550-F Gaming motherboard.
Every time I turn on the PC I hear a tick sound once when my MB’s status LED’s are changing righy before getting it to post and once again when I turn it off. I don’t hear that sound otherwise on idle or under load.
I checked my cables and everything seems to be correctly plugged in and I have no cables in the way of my fans so I don’t think I’m confusing the sounds.
Is my PC okay or should I replace my PSU?
Edit: I should also mention that I didn’t hear that sound when I couldn’t get the machine to post, it just occurs when booting correctly.
I think that’s just the relay.
If it’s the relay is it safe to hear that tick on startup/turn off?
Yeah, my psu does that too.
Yes. I have a standard PSU and an SFX one and they both click when the system powers on. It is totally normal to hear it.
The one that’s in my Seasonic Focus 750 Gold reverberates inside the PSU case, while the one in my Corsair SF600 Platinum is much more gentle but still very audible.
You can enjoy your system and not worry about this.
