I am building a cheap gaming rig and am stuck between choosing 2 cases, and it would help to know if a PSU mounted at the top, with the PSU fan pointing towards the CPU cooler(stock) would be an issue for my temperature, however I will have 4 fans in the case 2 of which are on the side panel blowing air at the CPU cooler.
If you need any more info just ask as time is not too important(don't build until January) and don't want to have any issues as I have been saving a while for this build.
well it won´t be realy an issue, but it will get blown hotter air trough the psu. i would personaly advice to buy a more uptodate case, with a bottum psu mounting, just for practical reasons.
Well, my opinion is this: the air coming from the other fans won't make the heat exhausted from the CPU cooler disappear during the few inches it travels to the top mounted PSU. Adding more fans will simply increase the amount of air, and therefore heat, that travels inside the case from the intake fans to the exhaust fans.
As for the possible PSU mounting positions.
1. Top mounted PSU means that hot air will travel through the PSU, making it run hotter.
2. Bottom mounted PSU with the fan up towards the inside of the case: it will run a bit hotter than with the fan pointed down, but you are risking dropping something inside the PSU when you work inside your case. EDIT: you can add one of those magnetic frame dust filters on top of the PSU fan this way though, to prevent you dropping something in it. And between the intake dust filters and the extra filter on the PSU vent probably no dust will ever get inside it.
3. Bottom mounted PSU with the fan pointing down: it will be the coolest, but you are also risking more dust being sucked into the PSU (dust tends to accumulate on the floor). And if your case is on a carpet, or the feet of your case aren't tall enough, you also risk not having enough air getting sucked in by the fan. There are also some Zalman cases with a weird fan slot pattern, something like very thin slits, where the PSU is positioned, which tends to limit the airflow. (EDIT: I think all the cases in the Z line from Zalman have this. I'm not saying that it will suffocate your power supply, I'm saying that it will probably run hotter because of the slits).
Thank you very much for the reply! :) It is very helpful, but just to check would you recommend avoiding a top positioned PSU or just that I should bear in mind that temps could be higher?
There are a lot of cases out there, you have several good options for practically every price range, so I would buy one with a bottom mounted PSU. But if you are really, really, really in love with a case with a top mounted PSU, buy a PSU from a known brand and you will be fine.
My first computer had absolutely no fans whatsoever, so all the heat was being evacuated through the PSU, which was a no-name PSU, the cheapest I could find. On top of that, I didn't clean at it all and it failed after two years of intensive gaming. The replacement was just as bad (same no-name PSU, again, the cheapest), but that one I cleaned regularly and it still works to this day.
I also have to admit that I haven't read of any kind of testing done to measure the air temperatures inside a case, and especially a few inches away from the CPU cooler, all of the tests measure the temperature of the components. I am just speculating here, but I can't imagine temperatures inside a case being hotter than 50 degrees (that's the common maximum operating temperatures of good PSUs). This is how I would do it: go to a friend's house, preferably one who has a similar CPU to the one that you plan to buy, convince him to stress test his CPU for 15-20 minutes, then put your hand over the back fan. If the air is hot, or very hot, you'll be fine. If it's so hot that it starts to feel painful to keep your hand there for more than a few seconds that's probably too hot for a PSU to handle.
