Newegg is having a sale and being a student on a budget I don't a heap of cash to throw out every chance I want or need. At the moment I am in need of a new PSU and am not sure which of these two I should go with.
At the moment I am running a pretty average system(back in the day it was quite a little monster) but it can handle BF3 in 1080 around 24fps. I know its the card 8800GTS that is the problem and I have a few "newer" cards I can throw at it until I purchase an R9 series card in the fall.
#1)At the moment I have a 470GTX ready to go and a pair of 450GTXs that can be SLI on the board I have. My main question is can either one of these will work for a the current SLI pair and work for R9s later this year.
#2)Does a PSU need to be SLI/Crossfire in order to run a pair correctly?
#3)Is there anything else in this price range I might have overlooked that is better? I would like to stay in the $70s area not trying to push over $90 and 80+
Two other options, i like the Corsair PSU's. (i have the 600M and its a nice bit of kit), I personally don't trust the cooler master PSU's i have heard/read about a few horror stories where they supply dirty voltages/amps or burn out on occasion.
Usually for SLi/Xfire its just the Wattage and power connections available that dictate if you can use sli/xfire.
Both of the Corsair PSU's are semi modular so you can also manage your cables better (so you can try to keep it tidy inside for better airflow/cooling)
I actually have an older Cooler Master 500 Extreme and it has done its job but lately I have noticed the fan sort of hitting the fan grill...not a major issue just yet but I would like to get rid of it ASAP
Need to get something much better than the 8800 running soon
I had a similar thing with an old Thermaltake PSU, i took it out and gave it a firm slam and it fixed itself :P
Although the 500 Extreme only has 1 6pin PCI-e connector and i wouldnt feel comfortable using such an old PSU on SLI/Xfire. (using some random molex converters)
Oh The Computer OverLords never ever would I use that for CrossFire/SLI. As far as amps go this guy is just enough to power the 8800GTS on the 12V its almost 10amps under what the 450s need and thats just for one. I hope that the new one(s) work out for me this is going to have to work another 4+ years as my past one did and is still is today.
