so I’m just gonna drop this in here so no one has to go through what I had to go through diagnosing something I never thought could even be an issue.
so I tried to use this pcie to m.2 adapter from “ORICO”:
ORICO-PSM2
with these samsung m.2 nvme ssds:
970 evo plus 1tb
the symptoms where:
samsung drives not showing up in bios, samsung devices showing in bios but some other pcie devices wouldn’t show up any more and even in this state I couldn’t install an os on the drive I have tested both linux (proxmox and ubuntu) and windows (server 2019 and win10 ltsc), with linux on loading the installer a kernel panic happened and system reboots, with windows installer would load but I was not able to get it to install, even trying to load one those winpe utility images would cause a crash (I have tested “Hikari pe”).
I have tested this combination on these platforms:
- HP DL380 G9 SFF
- Asus pro-ws-wrx80e-sage-se-wifi-ii running a 5995WX
- AMD b550 (5900x on a gigabyte vision D board I have tested all pcie ports on the board)
- some old asrock mb (don’t remember the board had a g1620 cpu I think)
the behavior was almost the same on all platforms however I was able to get the furthest on hp server but ultimately nothing worked.
on b550 board with a different m.2 ssd (Plextor 1TB M8Pe) the problem was gone.
So the issue was combination of this specific ssd (1tb 970 evo plus) and this adapter (orico psm2), which I still can’t get my head around.
I could literally SEE the card was nothing but a few traces capacitors and a connector (this adapter does not even has a voltage regulator).
I bought some other m.2 adapter and all the issues was solved (which was basically the same; some traces+few caps+a connector).
also do note I have tested THREE different ORICO-PSM2s and THREE different samsung 970 evo plus 1tb ssds.
