I just bought myself a mechanical keyboard, and hooked it up to the PS2 port. It seemed to work fine for a while, but every time my computer sleeps the keyboard stops working. A reboot of the computer fixes the issue, but then the issue just reoccurs again.
Has anyone had this issue before? It is happening with multiple keyboards that I have tested now, so I am pretty sure it is the port, not 3 different keyboards. Everywhere I read online says that it is the keyboard that is causing the issue, but that doesn't seem like the case here.
If I use the keyboard as a USB keyboard it works fine, but I would like to use the PS2 port if possible.
Thanks for any advice.
