Proxmox & TrueNAS NVMe-TCP Storage Configuration Guide
This is an example configuration of a Proxmox host connecting to two TrueNAS storage units utilizing mulitpath NVMe-TCP connections.
TrueNAS Server
Configure NVMe/TCP Shares in TrueNAS Community Edition
Create a ZFS zvol
Access the TrueNAS web interface
Navigate to Storage and create a new ZFS zvol that will be used for the NVMe share
Add NVMe-oF Subsystem
Go to Shares in the menu
Select NVMe-oF Subsystems
Click on Add to create a new subsystem
Configure Subsystem Settings
Namespace: Select the previously created zvol
Access Settings: Disable Allow any host to restrict access
Add the client’s host NQN from /etc/nvme/hostnqn
Enable Require Host Authentication if needed
Assign TCP Port and NAS IP
Set the TCP port to 4420 (default for NVMe/TCP)
Enter the NAS IP addressess for presenting the NVMe/TCP storage
Save and Start the Service
Save the configuration
Start the NVMe-oF service to enable the subsystem
Proxmox Server
/etc/network/interfaces
Example network configuration
auto lo
iface lo inet loopback
iface nic0 inet manual
iface nic2 inet manual
iface nic3 inet manual
iface nic1 inet manual
# Dedicated Storage Network Adapters
auto nic4
iface nic4 inet static
address 10.0.0.155/24
mtu 9000
auto nic5
iface nic5 inet static
address 10.0.0.156/24
mtu 9000
auto nic6
iface nic6 inet static
address 10.0.0.157/24
mtu 9000
auto nic7
iface nic7 inet static
address 10.0.0.158/24
mtu 9000
# Virtual Machine and Management Networks
auto vmbr0
iface vmbr0 inet manual
bridge-ports nic0
bridge-stp off
bridge-fd 0
bridge-vlan-aware yes
bridge-vids 2-20
auto vmbr0.2
iface vmbr0.2 inet static
address 172.16.0.55/24
gateway 172.16.0.1
source /etc/network/interfaces.d/*
Install nvme-cli
apt update && apt install nvme-cli -y
Configure ARP to prevent responses on wrong interfaces on the same subnet
cat > /etc/sysctl.d/99-nvme-tcp-arp.conf << 'EOF'
# ARP configuration for NVMe-TCP multipath
# Prevents ARP responses on wrong interface when multiple NICs share same subnet
# For dedicated physical interfaces
net.ipv4.conf.nic4.arp_ignore = 2
net.ipv4.conf.nic5.arp_ignore = 2
net.ipv4.conf.nic6.arp_ignore = 2
net.ipv4.conf.nic7.arp_ignore = 2
net.ipv4.conf.nic4.arp_announce = 2
net.ipv4.conf.nic5.arp_announce = 2
net.ipv4.conf.nic6.arp_announce = 2
net.ipv4.conf.nic7.arp_announce = 2
# For VLAN interfaces (uncomment if using VLANs instead of physical)
#net.ipv4.conf.ens1f0/100.arp_ignore = 2
#net.ipv4.conf.ens1f1/100.arp_ignore = 2
#net.ipv4.conf.ens1f0/100.arp_announce = 2
#net.ipv4.conf.ens1f1/100.arp_announce = 2
# Global settings
net.ipv4.conf.all.arp_ignore = 2
net.ipv4.conf.default.arp_ignore = 2
net.ipv4.conf.all.arp_announce = 2
net.ipv4.conf.default.arp_announce = 2
EOF
Apply ARP settings immediatly and verify
Apply ARP settings
sysctl -p /etc/sysctl.d/99-nvme-tcp-arp.conf
Verify ARP settings
sysctl net.ipv4.conf.nic4.arp_ignore
sysctl net.ipv4.conf.nic5.arp_ignore
sysctl net.ipv4.conf.nic6.arp_ignore
sysctl net.ipv4.conf.nic7.arp_ignore
Load NVMe kernel modules
modpobe nvme
modprobe nvme-tcp
modprove nvme-core
Make NVMe kernel modules persistent across reboot
cat > /etc/modules-load.d/nvme-tcp.conf << 'EOF'
nvme
nvme-tcp
nvme-core
EOF
Verify NVMe kernel modules are loaded
lsmod | grep nvme
Expected output: nvme, nvme_tcp, nvme_core
Enable multipath
echo 'options nvme_core multipath=Y' > /etc/modprobe.d/nvme-tcp.conf
Verify multiapth is enabled
cat /sys/module/nvme_core/parameters/multipath
Expected output: Y
Discover and mount NVMEe-TCP drives
Display Proxmox host NQN
cat /etc/nvme/hostnqn
Example output: nqn.2014-08.org.nvmexpress:uuid:*********************************
Create discovery.conf with paths
Each line defines one path: host interface → storage portal, note that there are two storage servers and portals, 10.0.0.40 & 10.0.0.150
cat > /etc/nvme/discovery.conf << 'EOF'
# NVMe-TCP Discovery Configuration
# Format: --transport=tcp --traddr=<portal> --trsvcid=<port> --host-iface=<iface> --host-traddr=<host-ip>
# Interface 1 (nic4) -> All Portals
--transport=tcp --traddr=10.0.0.40 --trsvcid=4420 --host-iface=nic4 --host-traddr=10.0.0.155
--transport=tcp --traddr=10.0.0.150 --trsvcid=4420 --host-iface=nic4 --host-traddr=10.0.0.155
# Interface 2 (nic5) -> All Portals
--transport=tcp --traddr=10.0.0.40 --trsvcid=4420 --host-iface=nic5 --host-traddr=10.0.0.156
--transport=tcp --traddr=10.0.0.150 --trsvcid=4420 --host-iface=nic5 --host-traddr=10.0.0.156
# Interface 3 (nic6) -> All Portals
--transport=tcp --traddr=10.0.0.40 --trsvcid=4420 --host-iface=nic6 --host-traddr=10.0.0.157
--transport=tcp --traddr=10.0.0.150 --trsvcid=4420 --host-iface=nic6 --host-traddr=10.0.0.157
# Interface 4 (nic7) -> All Portals
--transport=tcp --traddr=10.0.0.40 --trsvcid=4420 --host-iface=nic7 --host-traddr=10.0.0.158
--transport=tcp --traddr=10.0.0.150 --trsvcid=4420 --host-iface=nic7 --host-traddr=10.0.0.158
EOF
Enable and start the autoconnect service for automatic connection on boot
systemctl enable nvmf-autoconnect.service
Connect all NVMe-TCP drives and verify connections
nvme connect-all
Verify connections
nvme list-subsys
Example expected output:
You should see a line for each physcial NVMe and lines for the paths specified in your /etc/nvme/discovery.conf file
nvme-subsys0 - NQN=nqn.2014.08.org.nvmexpress:********************** SAMSUNG MZVLB512HBJQ-000H1
hostnqn=nqn.2014-08.org.nvmexpress:uuid:******************************
+- nvme0 pcie 0000:26:00.0 live
nvme-subsys2 - NQN=nqn.2011-06.com.truenas:uuid:*************************:nvme0f01
+- nvme2 tcp traddr=10.0.0.40,trsvcid=4420,host_traddr=10.0.0.155,host_iface=nic4,src_addr=10.0.0.155 live
+- nvme4 tcp traddr=10.0.0.40,trsvcid=4420,host_traddr=10.0.0.156,host_iface=nic5,src_addr=10.0.0.156 live
+- nvme6 tcp traddr=10.0.0.40,trsvcid=4420,host_traddr=10.0.0.157,host_iface=nic6,src_addr=10.0.0.157 live
+- nvme8 tcp traddr=10.0.0.40,trsvcid=4420,host_traddr=10.0.0.158,host_iface=nic7,src_addr=10.0.0.158 live
nvme-subsys3 - NQN=nqn.2011-06.com.truenas:uuid:***************************:nvme0f01
+- nvme3 tcp traddr=10.0.0.150,trsvcid=4420,host_traddr=10.0.0.155,host_iface=nic4,src_addr=10.0.0.155 live
+- nvme5 tcp traddr=10.0.0.150,trsvcid=4420,host_traddr=10.0.0.156,host_iface=nic5,src_addr=10.0.0.156 live
+- nvme7 tcp traddr=10.0.0.150,trsvcid=4420,host_traddr=10.0.0.157,host_iface=nic6,src_addr=10.0.0.157 live
+- nvme9 tcp traddr=10.0.0.150,trsvcid=4420,host_traddr=10.0.0.158,host_iface=nic7,src_addr=10.0.0.158 live
Create udev rule for automatic IO policy configuration
cat > /etc/udev/rules.d/99-nvme-iopolicy.rules << 'EOF'
# Set IO policy to queue-depth for all NVMe subsystems
ACTION=="add|channge", SUBSYSTEM=="nvme-subsystem", ATTR{iopolicy}="queue-depth"
EOF
Reload udev rules and apply to existing subsystems
udevadm control --reload-rules
udevadm trigger
for subsys in /sys/class/nvme-subsystem/nvme-subsys*; do
echo "queue-depth" > "$subsys/iopolicy" 2>/dev/null || true
done
Verify udev rules
cat /sys/class/nvme-subsystem/nvme-subsys*/iopolicy
Test NVMe-TCP persistent connections with a reboot
Reboot the Proxmox host
reboot
Add new storage to the Proxmox host
Run ‘nvme list to see the NVMe-TCP connected disks and create the volume groups for the disks
nvme list
vgcreate nvme_vg /dev/nvme0? # replace /dev/nvme0? with the name of NVMe device provided from the 'nvme list' command
In the Proxmox UI, Datacenter, Add, select LVM storage, nvme_vg
thanks @Glitch001
After reboot, verify that the NVMe-TCP connections reconnected automaticly
nvme list-subsys
nvme list
Create a boot pause service to wait on network to come up before autoconnecting to NVMe-TCP
If your network does not come up before the nvmf-autoconnect.service runs, create a service to wait on the network service to come up before running the nvmf-autoconnect.service
cat > /etc/systemd/system/nvmeOF-boot-pause.service << 'EOF'
[Unit]
DefaultDependencies=no
After=nss-lookup.target
Before=nvmf-autoconnect.service
[Service]
Type=oneshot
RemainAfterExit=yes
TimeoutStartSec=60s
ExecStart=sh -c 'until ping -c 1 $HOST; do sleep 1; done' # Replace $HOST with IP address of storage portal
[Install]
WantedBy=nvmf-autoconnect.service
EOF
Enable nvmeOF-boot-pause.service
systemctl enable nvmeOF-boot-pause.service
reboot
TrueNAS Scale now has a NVMe-oF/TCP plugin for Proxmox. I haven’t tried it out myself, but it’s there.
Another note from TN 25 Halfmoon?, the current NVMe-oF/TCP is faster using File versus Zvol for some reason, at least in my testing. If using Special Vdev, both File & Zvol will write to the SVDEV per settings of the block writes. NVMe-oF/TCP is the only option available in the Community edition of TN & RoCE/RDMA is not available. NVMe-oF/TCP will only allow Disk Image & Containers, so no Backups or any other functionality you will get from NFS or SMB.
An abridge version of the above:
Adding NVMe-oF/TCP:
apt update && apt -y install nvme-cli
modprobe nvme_tcp
echo “nvme_tcp” > /etc/modules-load.d/nvme_tcp.conf
nvme discover -t tcp -a “ip of TrueNAS“ -s “port”
nvme connect -t tcp -n “nqn of NVMe-oF” -a “TrueNAS ip“ -s “port“
echo “discover -t tcp -a “TrueNAS ip“ -s “port”” | tee -a /etc/nvme/discovery.conf
vgcreate nvme_vg /dev/nvme0n1
In Proxmox UI, Datacenter, Add, select LVM storage, nvme_vg
You can move the VM>Hardware>Hard Disk, Disk Action
Thank’s @Glitch001 I didn’t have much luck wit the TrueNAS Proxmox Plugin when it was initially released, it has a problem with multiple paths. I will have to try it again.
I performed a benchmark in a winblows vm of file based vs vol based NVMe/TCP volumes
Vol based:
File based:
Interesting results, I will definitely convert everything to file based vols on TrueNAS for the time being.
So my testing during Halfmoon was exactly what you were getting for File on zvol, but something’s changed since that have impacted zvol greatly for writes.
It used to be the other way around, zvol’s were faster. I’m not sure if TrueNAS was based on BSD when I last tested it, but it was a while ago.
I tested Halfmoon around Feb time frame, 26.04, and zvol was just as fast as what you tested above for file. Halfmoon is Linux. I’m currently on the 28 Nightlies, and zvol is just not as fast as file.
